Original Overdrive Help!
Hello all. I'm finally at a point where I can spend a few hours a day working on my 65 c10. I have never operated the overdrive on this truck.
Question: Should I do any maintenance to the transmission before trying to engage the overdrive? I know there are switches on the carburetor. How would I check these out? Next Question: How in the name of Zeus' butt hole do I operate this overdrive? Thanks. |
#2 | ||
"I ain't nobody, dork."
Re: Original Overdrive Help!
Not sure of any "factory" overdrives from that era, so it was possibly an aftermarket deal. Or maybe even a dealer add on. Post up some pics will make it easier to identify.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
![]() Join Date: Sep 2006
There should be a cable to pull under the dash. After you pull the cable and over 55 MPH I believe the O/D will kick in if the servo's are connected. I put an O/D unit in my 65 and hooked up a switch to override the Servo switch. I just do it manually. So I have to pull the cable and flip the switch. The trans I used was from 1957 according to the #'s on the case.
This is what an O/D unit looks like. I had 3. I sold one and put on in my truck and this one is sitting in my garage. It needs a full rebuild.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Have a look on this website. They have the original manuals posted on 3speed overdrive transmissions.
Hope this helps. Regards Steve http://devestechnet.com/Home |
