disc brakes and drop spindles????
I have a 66 c10 , the PO did a disc brake conversion on it. I am wanting to install drop spindles , most of the drop spindles require converting to 71-72 disc brakes or equivalent. Am I in the clear or do I have convert ?
THANKS ![]() |
Re: disc brakes and drop spindles????
I had to buy a bracket to bolt my disc brakes up to my drop spindles. PO also did a disc brake conversion, although I replaced it all with new.
I'd get the spindles and see if they bolt up. If not you can get some different mounting brackets likely. |
Thanks AZ
I guess I'm going to pull the trigger. I think I'm going to contact belltech and see what the say or if they sell a bracket. |
![]() Join Date: Jan 2011
First thing to do is identify what was used to do the disc brake conversion. Many of these trucks with out a drop have the 73 to 87 stuff in them. They are the easy ones to find. They also could have 1" or 1 1/4" rotors. So before you order anything post some pictures and lest make sure you are on the right path.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
