![]() Join Date: Jan 2012
Gmc chevy Cadillac k10 k20 one piece at a time your thoughts please
Bought this truck has gmc frame with v6 mounts gmc grille, horn button, tailgate.2 vin tags one for gmc 64 1/2 k1000 and 65 chevy c20. Power train from 1970 Cadillac 472 turbo 400 rockwell divorce t case dana 44 closed knuckle front eaton rear 3/4 ton axles. On board air tank and hose. Previous owner pulled v6 and farm installed compressor to run air. And installed Cadillac 472. Plans were to put gmc body and v6 from a 62 that I have but kinda like the Cadillac 472 power. Probably will leave it and make reliable as brakes are not good and has been sitting for a while.
Re: Gmc chevy Cadillac k10 k20 one piece at a time your thoughts please
More photos
![]() Join Date: Dec 2009
I really like your Truck.
I am very familiar with the 472 Cadillac engines. That brings back good memories too me. Those are engines that will Last/ and have a lot of Power.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
More Photos
60-66 Nut
![]() ![]() Join Date: Mar 2007
looks and sounds like an Idaho truck
![]() I would be careful about talking about an extra VIN tag since that is illegal and in Idaho can get your vehicle confiscated.
My other trucks. 1963 gmc massey Ferguson shop truck. White 62 gmc dads truck.64 c0 292 crurrent yard art. Sorry don't know how to rotate photos. Truck hlis currently titled in my name from the 65 but had a secon registration paper labeled vin 2
Registration paper
That is a Nice collection.
I like all three of those. What is the plans for them?
Drive them when I can fix them when I cant
BLAZER THIRTY!!
![]() Join Date: May 2007
nice rides I'm partial to the white 62!
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
BLAZER THIRTY!!
pull the body off clean up and drop dads v6 in make it prettty like your 63 then put out his body on the frame I would love to see that, and would love to help make it happen
Progress so far. Found all springs and hangers shot. Leaking t221 not cost effective to fix. Found replacement divorced np205 from international pickup. Was going to use Eaton axle swapping out the 4.57 gears to 4.10 with no spin but pinion pilot bearing toast. Using 79 k20 14 bolt and Dana 44 with front tuff country 6 inch lift springs from 72 Chevy and rear 56 springs and shackle flip from 77 c10 heavy half
#13 |
Axle mock up and front spring hanger mod. T CASE mockup and toast 4.10 Eaton pinion.
#14 |
Rear of frame por 15 and top coat with John Deere medium black. Had to use square body frame supports on front crossmember as left side was rusted out and held spring hangers better. Using Ord greaseable bushings in the Rear
#15 |
Leaf springs and 14 bolt next
#17 |
Looking good.
![]() Nice work. .
#18 |
![]() Join Date: Jan 2011
The progress looks good. I would have never started on it where I live. That GMC tag clearly removed and put on a chevy cab with a vin tag that you don't have a title for would never fly.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#19 |
My Thoughts.....
Ditch that VIN that doesnot match that frame
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
#20 |
As far as I can tell none of the gmc frames have the vin on them, I have 3 and can't find any so I will just keep the titled vin tag for now.
#21 |
60-66 Nut
That is correct. The GMC frames do not have VIN numbers on them.
#22 |
I would do what you have to to get a title for the cab and the untouched vin tag. What you have now is illegal in so many ways both on a state and federal level.
Jimmy
#23 |
i have the title for the chevy cab , i will try to see if i can title the gmc vin tag
#24 |
You need to title the chevy cab. That cab with the original vin tag attached is the vehicle you have no matter the rest of the mods. That GMC vin tag should never see the light of day.
Jimmy
#25 |
60-66 Nut
I would suggest reading post #5 again. I do know what I am talking about. My late father inlaw was with ISP for many years and told me about what can happen. If you are not careful ISP may pay you a visit and it won't be good.
| Bookmarks |
