07-29-2018, 10:13 AM | #1 |
Active Member
WTB '72 402 orig hardline fuel pump to orig quadrajet
Another one, from classic ind. not even close, frustrating. Would like to buy an original quadrajet to fuel pump line for '72 swp 402 auto air. Condition unimportant, just need it to bend a new one that will actually fit. Thanks
07-29-2018, 12:23 PM | #2 |
Re: WTB '72 402 orig hardline fuel pump to orig quadrajet
Would a 350 fuel line be the same? I was planning to copy the 1 I have.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
07-29-2018, 01:49 PM | #3 |
Moderator
No, the 72 402 fuel line is unique and not reproduced. You need to locate an original.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-30-2018, 08:38 PM | #4 |
Active Member
Hey Rob, good deal, update when you find out
07-31-2018, 09:09 AM | #5 |
How are the reproductions of the 68-71 hard fuel line?
07-31-2018, 09:48 AM | #6 |
Equal opportunity joke ofender
Harry
I have a 72 402 longhorn sitting here. I will check to see if the original line is still on it. I don't want to sell it but I would be ok with letting you use for reproducing, if I can get it off. I assume you need pretty soon? Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
07-31-2018, 10:19 AM | #7 |
Scratch that Harry, someone cut the upper half to add an inline fuel filter and rubber hose.
07-31-2018, 05:03 PM | #8 |
07-31-2018, 08:12 PM | #9 |
Harry if this looks like it I will get one made for you from Fine Lines wadsworth Ohio I have a buddy that works there
08-01-2018, 12:46 PM | #10 |
Yeah I had a perfectly good one on my truck a couple years ago and I was having some issues with the quadrajet running right. . .well my sisters boyfriend was around the weekend it was acting up. . guess what he did? went into oreillys and had me buy a holley to swap on. . not thinking anything of it besides well this will be nice to get it back on the road quick. I can rebuild the quadrajet later. . he mounted the holley on and I had to grab something from inside the house. . by the time I got back out. . he used a hack saw and cut the hard line so he could put a rubber hose onto it to make the fuel line easier to mount up to the holley!!!! Ahh!!! I was pretty irritated with him for a while. . I did also buy a line from classic tube. . and I can't get it to mount up to the fuel pump correctly without leaking. . I did have to bend the line with a tubing bender just to get it to go into the fuel pump hole also. still didn't fix the problem. So . . I know what you guys are talking about
08-01-2018, 12:50 PM | #11 |
the only thing I have yet to try. . and if someone has already tried it on here, please tell me your experience. . but I saw in a Hot Rod magazine a week ago. . an ad for this stuff called Seal Lock by Permatex . . can be used on fuel, coolant, power steering, brake systems, A.C. and plumbing connections. . I have not bought any yet and maybe its a waste of money.
08-01-2018, 04:42 PM | #12 |
ok, help me out here. I had an original line on my BB but bought inline tubes fuel pump to carb line. Asked if they wanted mine for a pattern but they said no, we have that one. So Inline won't work?
Posts on here make it sound like my SS line won't be right and I threw away a valuable part. Bends seemed to match, they're always just a touch longer. I guess I need to go test fit on rebuilt motor |
08-01-2018, 07:15 PM | #13 |
Active Member
Here's one from inline that's really not even close.
Richard, Thanks for trying, that's what I have now, cut top portion with rubber hose. Gunner your pictures look correct, sure worth a try. Thanks |
