Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 07-29-2018, 02:49 PM   #1
63suburban
63suburban's Avatar
Outer Body Mount
I started to do the repair to the passenger floor on my 63 burb and the body supports are rusted out. Since the truck sheet metal is different, working on fabricating something but part of the mount is missing.
Does anyone have any photos or illustrations/diagrams of the suburban body support?
Thanks.
1963 Chevrolet Suburban
63suburban is offline   Reply With Quote
Old 08-04-2018, 02:28 PM   #2
notsolo
notsolo's Avatar
Re: Outer Body Mount
Your body work, metal skills are looking great. I have a 62 panel, I could be wrong, but I think most of the floor supports look the same. Is that piece behind the door, transition up to the wooden floor? I can get you photos of them etc....Ed.
notsolo is offline   Reply With Quote
Old 08-04-2018, 03:31 PM   #3
63suburban
63suburban's Avatar
Thanks alot. Appreciate it. Pretty sure they are the same. Different than the truck that is for certain. Been trying to keep at it slowly but surely.
Planning to fix the body mount before doing the inner rocker floor. More room for access and then can treat the rust up inside the body mount.
The piece that transitions up to the wooden floor is further back, Right where the rocker panel meets the rear bedside There is a 90 degree bend that then drops down in between the outerbody mount. I attached a photo of a view from the bottom back of the rocker and then where the floor meets the wooden area. There is a curve there and then the way the floor is flat skews the body mount where it is wider where it meets the outer body. Not sure if there should be a gap or drain hole where as well.
The view from the rocker helps to show what is missing on my body mount. The floor photo shows how the 90 degree bend meets the floor.
Really love to see a photo if you can take one or three. Front view back view and bottom view. Bottom view being most important.
Old 08-04-2018, 05:22 PM   #4
notsolo
notsolo's Avatar
This is the drivers side, undercoating and drop down for fuel switch ? or something blocks decent photo. Brace looks close, Suburban metal floor goes back further, I will get a better photos of the passenger side later....
Old 08-04-2018, 05:54 PM   #5
63suburban
63suburban's Avatar
Thanks for sharing! You Rule. Really Appreciate it. My drivers side outer body mount is also rotted out. Looks the same. the outer body support on the burb/panel Is shorter on the drivers side vs the passenger side, since the driver side does not have to account for the jump seat on the passenger side.
To the left of the photo, the drop down is the inner frame to body mount. Pretty sure I should have worded this thread "outer body support". Since it supports the body and does not attach to the frame.
Has the rubber bushing w bolt. Photo angles from bottom up would be helpful.
Old 08-04-2018, 06:41 PM   #6
notsolo
notsolo's Avatar
Will do, trying to figure out how to get a decent photo that shows details not just a blob....
Old 08-05-2018, 09:56 AM   #7
notsolo
notsolo's Avatar
Sorry for the delay, mowing sucks...lines on cardboard 1"
Old 08-05-2018, 10:00 AM   #8
notsolo
notsolo's Avatar
Backside
Old 08-05-2018, 10:09 AM   #9
notsolo
notsolo's Avatar
More, looks like body mount is intigreted with the support. MaY not be the same piece...lmk...if you want a cardboard template.
Old 08-05-2018, 12:04 PM   #10
notsolo
notsolo's Avatar
White out...1 left other rt.
Old 08-05-2018, 03:17 PM   #11
63suburban
63suburban's Avatar
Thanks alot!! really appreciate you taking the time.
The panel looks like the burb supports.
Old 08-05-2018, 03:53 PM   #12
notsolo
notsolo's Avatar
Hope it helps, ...there are 2 stamped finger depresions about 4" apart, probably strengthens the piece.
Old 08-05-2018, 04:30 PM   #13
63suburban
63suburban's Avatar
Thanks, Yes that helps. Appreciate it.
I would have never have guessed there is a lip at the bottom rear of the passenger side body support. Was just going to make the passenger side like the driver's side.
Looks like the depressions are the differences on the panel. Same with where the body support bolts to the body.
What year panel do you have?
if it is not too much trouble, a pic of the passenger side view from bottom or 3/4 angle. Trying to see where the body supports meets the rocker.
Thanks!
Old 08-05-2018, 05:25 PM   #14
notsolo
notsolo's Avatar
I will try and get a better photo, the shot with the white cardboard shows the bottom edge. That edge is open on rt side and left side, tips away from the 90 degree like it might have been to shed water... I know the undercoating obscures any decent photo. Also looks like about 1/2" up from rocker lip, maybe even, with rocker. I will check.
Old 08-06-2018, 10:04 PM   #15
63suburban
63suburban's Avatar
Thanks.
Old 08-08-2018, 04:53 PM   #16
notsolo
notsolo's Avatar
Meanwhile!....my panel is a 62..cardboard template is 11" x 14"....11" is up under the plywood floor on mine, yours is lower I think with the bump up in the back, maybe 3"...rocker is even with the bottom, lip hangs down 1/2"...
Old 08-08-2018, 04:56 PM   #17
notsolo
notsolo's Avatar
Probably not the photo you needed. 1" grid.
Old 08-09-2018, 12:31 PM   #18
63suburban
63suburban's Avatar
Awesome. Thanks alot. Really appreciate you taking the time to post up those photos.
