Old 07-29-2018, 06:13 PM   #1
plowro8
What to do with cut AC
I am getting ready to drop a new engine into my 72 and the AC has been chopped. At this point, I don't have intentions of ever having the AC fixed, but I cant fully rule out the possibility in the future. What should I do with this situation to clean it up, in case I should ever decide to work on the AC? Or, does it just make sense to eliminate all the parts associated with it and take the possibility out of play?
plowro8 is offline   Reply With Quote
Old 07-29-2018, 06:27 PM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: What to do with cut AC
If it was Me, I would get rid of it all,and if down the road you want air,go with one of the aftermarket ones, cleans up under the hood,better compresser,and just a better system overall,just if it was mine.
Redneck Rydes is offline   Reply With Quote
Old 07-29-2018, 07:18 PM   #3
FRCvette
I would do the same as Redneck says. If it is not going to be operational no need to have it there.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 07-29-2018, 08:44 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Ditto with RedNeck...get rid of the clutter...
You will need a different belt for fan alt etc...
AussieinNC is offline   Reply With Quote
Old 07-29-2018, 08:55 PM   #5
plowro8
Why a different belt? I don't see where anything related to the AC is tied into the belts and pulleys... but then again, I don't know much about anything under the hood.
Old 07-29-2018, 09:02 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
So there is currently on drive belt on the AC compressor?
Difficult to tell from that pic...
The belt that drives the water pump, alternator must be in place...
Old 07-29-2018, 09:07 PM   #7
thelonerife
thelonerife's Avatar
I would get rid of all the stock stuff. I spent good money on trying to save the original ac just to be disappointed with failing compressors. I went with vintage air on a couple trucks and it was the best decision ever.
thelonerife is offline   Reply With Quote
Old 07-29-2018, 09:14 PM   #8
weq92f
weq92f's Avatar
A/C is good in winter also for bringing the moisture out of the cab... also on rainy days/nights!
That said. I agree with the others on the aftermarket, especially if the stock stuff is already worn down or broken.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-29-2018, 09:20 PM   #9
plowro8
There's only two belts... One for the alternator and water pump and one going to power steering.
Old 07-30-2018, 08:21 AM   #10
stormtown
When you get AC delete plate and bolted on, PM me, I may buy your AC box. Mine has a crack in it.
stormtown is offline   Reply With Quote
Old 07-30-2018, 08:36 AM   #11
plowro8
Do you happen to have a link to the AC delete plate I will need, and will it still allow for the heater and defrost to work?
Old 07-30-2018, 11:51 AM   #12
clay68c10
clay68c10's Avatar
Pull off the manifold hose set, cap the lines, and just leave it be. If the heat/def and ventilation are working then call it good for now.
If you pull that evaporator case off and get rid of it, you won't be able to buy it again for the same money you sold it for.
Those replacement systems are slick, but not cheap.
You can refurbish the whole system piece by piece over time and not spend a lot of money if you enjoy the tinkering. They do work well. If you are hiring it out, then not so much.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-30-2018, 12:51 PM   #13
Andy4639
Old member
Andy4639's Avatar
Personally I would keep it as it is until money is there to fix it all back and in the end make the truck worth more value.
These can be modified to run great with 134a. Just a little work and it will blow cold.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-30-2018, 03:07 PM   #14
MARKDTN
I too would fix it. It appears to be mostly there.
The fan is outside so you would need a way to keep it if you want heat.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-30-2018, 03:15 PM   #15
plowro8
What exactly do I need to keep if I want heat? Which fan are you referring to?
Old 07-30-2018, 07:42 PM   #16
stormtown
He's referring to the heater blower fan. As you're at the front of the truck it is on the L side of the evap core housing. Closest to fender
Old 07-30-2018, 07:46 PM   #17
plowro8
So could I just leave the big AC box in place and remove all the AC lines that connect to it and clutter up the space under the hood, then still have heat? Sounds like a bunch of work to remove the AC and keep the heat, based on what I've read.
Old 07-30-2018, 07:47 PM   #18
stormtown
It is more work for just heat, but everyone is saying keep the original stuff and get AC working over time if you want
Old 07-30-2018, 07:48 PM   #19
stormtown
Andy4639 has a newer sanden compressor and receiver from 74 on up style AC but he kept the original evaporator and box is what he's showing
Old 07-30-2018, 07:50 PM   #20
stormtown
you can check with faabenny on the site but he would probably tell you to leave lines connected and take elec feed off compressor until you decide what to do. I know when I was talking with him about mine he wanted to know if the lines were still connected, better chance of less corrosion and valves all still working.
Old 07-30-2018, 08:32 PM   #21
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What to do with cut AC
I would leave it all in place and just take the wire loose on the clutch switch on the inside of the floor vent which is what kicks the compressor on. This way everything looks like it suppose to and once you decide to fix it you know where everything is.
You have to have power to the fan switch & controller in the dash for the heater to work anyway. The heater hoses connected to the water pump on the motor to the heater core.
Old 07-31-2018, 04:37 AM   #22
F.A.A.benny
From your picture, looks like the condenser and compressor are missing. Doesn't look like anything else is missing. You can remove The a.c. hoses and just cap off the poa valve and expansion valve. The Orange hoses are for your heater. You don't want to remove the a.c. box if you want to keep the heater. If you remove the ac box to add a block off plate, the blower motor goes with the a.c. box and no more heater.
F.A.A.benny is offline   Reply With Quote
Old 07-31-2018, 07:36 AM   #23
plowro8
Okay, that's what I needed to know. Thanks
