07-29-2018, 11:54 PM | #1 |
Shocks for Lowered S10 Chassis
My AD truck is mounted on a 1993 S10 chassis which has been lowered three inches in both the front and the rear. I would like some recommendations on shocks front and rear. I am looking for good ride quality and reasonable handling.
Thanks. Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
07-30-2018, 12:26 AM | #2 |
Re: Shocks for Lowered S10 Chassis
how you lowered it matters. for example, if you lowered it with 2" spindles and a 1" coil spring, the change to the shock is only 1". in the rear, if you used a 3" block, you did not change the shock length at all.
conversely, if you used 3" drop coils and stock spindles, the change to the shock is a full 3". if you used a 3" dropped leaf, the shock change is 3" again. but at only 3", stock length shocks are fine. I did a lot of research into what shock belltech sells for 3" coil drops and found out the 79 mazda b2000/sundowner uses that same length, but I put it next to a stock s10 shock and it was the same, extended and compressed. belltech street shocks are great but expensive for a twin tube. you can buy a monotube gabriel or monroe for that money. lowered suspensions usually have a higher spring rate and will oscillate more, which will foam a gas charged twin tube on a rough road. monotube shocks are better performance all around but are much more expensive. with all that said, on my trucks that I lower 3-4" with coil springs and spindles and leaf springs and blocks, I use monroe gas charged shocks, $32 ea front and rear.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-30-2018, 02:58 PM | #3 |
Have to go with what he suggested, That said you have to pick the right shock for the ride you want to have as every one of us is a bit different in that respect. What is perfect to Joe may be a bit mushy to you and a bit hard riding to me. My daily rides so stiff that anything with an S-10 two wheel drive chassis would seem smooth though.
Rock auto says that the Monroe 32132 is the standard length shock that being Extended Length (in): 13.370 in. Collapsed Length (in): 8.680 in. That shock fits just about every mid size GM rear wheel drive rig so finding something shorter will take some hunting. The rears might be easier but I am having trouble finding the stock lengths for a rear shock. for the S=10
