Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 11-15-2003, 02:36 AM   #1
jack'd up
Clip Front End
What year Camaro/firebird do you use to clip the front end on a 55 1st . I have heard of '70 to '81 and '82 to '92. I have an '84 Firebird that I would like to use wil it work?
Thanks, Dennis
jack'd up is offline   Reply With Quote
Old 12-03-2003, 10:22 PM   #2
pugs
pugs's Avatar
i would go with the earlier70-81 but just my preference as i have never done this type of swap yet but i have friends the have and they either went w/ the early camaro or nova
Pugs
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 12-12-2003, 10:51 PM   #3
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Why cut your frame in half? Go with a Mustang II clone IFS . I did and it is easy and you don't need to cut off the inner fenders and do a bunch of fabrications to remount the radiator, front bumper and etc. I recommend a Martz Engineering Chassis with its full 1/4 inch crossmember and its ability to avoid cutting off the bottoms of the inner fenders. My two cents worth ... rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 12-30-2003, 03:39 AM   #4
rico_bob
"Treasure the Ride"
rico_bob's Avatar
CHECK OUT THIS THREAD!
http://67-72chevytrucks.com/vboard/s...threadid=83067
Old 11-24-2004, 10:37 PM   #5
lou's bad 4x4
I have a 79 sub frame, too wide for the front end. I am going to put a Total cost involved independent supension in my 54 truck, it bolts or welds right in the frame. Rico bob is right, this better way to go. There is many business out there, Heidt's , fatman,and others. I am also putting in a 4 bar ling in the rear end.
lou's bad 4x4 is offline   Reply With Quote
Old 11-25-2004, 11:52 AM   #6
Seon
Seon's Avatar
Pugs is right on with the years..'70-'81 Camaro, Firbird or Nova.
Here's a pic from last summer of my daughter and I installing an '80 clip in her '52 Burb.
Seon is offline   Reply With Quote
Old 11-25-2004, 08:13 PM   #7
44th Miss Inf
On my 55 1st series, I used, would you believe, the front end from a 76 AMC Pacer. Only required 2 easy to fab plates to add the crossmember. Bone yard GAVE me the clip to get rid of it. This was 15 years ago. Still see the truck around occasionally. If I can run it down, I will get pics.
Virgil
44th Miss Inf is offline   Reply With Quote
Old 11-25-2004, 11:23 PM   #8
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
You might have a look at this before you decide.You'll have to join up to see the thread but it's worth it
http://www.jalopyjournal.com/ubbthre...5&o=&fpart=all
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-01-2004, 07:50 PM   #9
Don Meyer
I have put IFS under a dozen of the AD trks(47-54). The best fit is the Must II & the down sized Chevelle,Buick Regal,Olds Cutless....etc. These late model GM front suspensions(84-88?) are 3" narrower than the the 2nd series Camaro.
They are much cheaper than the Must II. They come w/disc brakes,anti sway bar,PS.
There have been a few failures of the lower control arm on the Must II that have the strut rod eliminator.
Don
Don Meyer is offline   Reply With Quote
Old 12-02-2004, 01:27 PM   #10
crews
It just doesn't matter
A friend of mine used an S-10 clip. Perfect width, and the replacement parts are readily available.
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 12-02-2004, 04:45 PM   #11
pugs
pugs's Avatar
well since i had sold off my 54 chevy, Im in process of decideing whether or not to replace the clip on my 47 international project, I dont like the way it was done, or just go w/ an s-10 chassis when i get to that point i will take pics of what i do
Pugs
Old 12-08-2004, 04:25 PM   #12
Don Meyer
The second series is too wide. Try the late model chevelles....ie 86
