Resistors for gauges different??
Are the resistors for the fuel gauge and the Temp gauge different values? My fuel gauge isn't working properly after I put my cluster back together after painting it and for some reason my temp gauge keeps pegging to hot also. Both gauges worked before I took cluster apart. If I got the resistors backwards would this happen.
Thanks!! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Black 72 Chevy
It sounds like your temp guage is shorted.
hmmmmmm.... I'll check that out.
The resistors are different between temp and fuel. ?They can also be different between gauge clusters by year as I have seen several variations. My first truck had a bad resistor on the fuel gauge--drove me nuts trying to get it to work till I exchanged it with another one---fixed!!
Can someone tell me how to test these things with a digitsl multimeter? What values I should be looking for??? Thanks for everyones help!!!!
