Old 08-02-2018, 10:59 AM   #1
nlped
nlped's Avatar
'77 on a '71 frame, or some sort of homogenization??
Okay,
I just bought my '77 2wd swb C10 this past weekend and drove it home from Chattanooga and it did fine. The suspension is a bit sketchy as it has cut front springs with spring spacers twisted into them and the rear only has 3 leafs remaining, so its a bit "loosie goosie" to drive.
Now...I have a '71 swb C10 frame here at the house, along with complete Porterbuilt front mild DropMember and a complete rear touring DropMember that I was going to put under my '68. But I'm a squarebody guy that tried to go '68. It just didn't happen, so I want to try and build this '77 with the PB stuff I already have.
I know all the rear of the '77 vs the '68 frames are COMPLETELY different after about a foot past the trans crossmember, so that would have to be 'retrofitted'. But with a touring DropMember, the bed floor would have to be modded anyway, so that doesn't seem like a major hurdle. And I know the 67-72 and the '73 up K-members interchange as I have done it on a '70 GMC, so the front DM should work either on the current '77 frame, but what about the '71 frame under the '77? Feasible? Without crazy modifications, will this work? Has anybody done this?
And, I did search prior to posting and never found a definitive answer either way.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-02-2018, 11:51 AM   #2
RADustin
Re: '77 on a '71 frame, or some sort of homogenization??
I'd sell what you have and find another used setup to put on your frame. IMO.
On the front- aren't the 4 holes different on the sides of the frame?
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 08-02-2018, 12:28 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I believe the front dropmembers are slightly different in the frame height.
Meaning the 73-87 frames are a little taller. Which doesn’t really matter except where the PB piece goes inside the front frame rails.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 08-03-2018, 07:27 PM   #4
cadillac_al
I would buy some new springs for the 77 and enjoy it as is.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-03-2018, 08:35 PM   #5
nlped
nlped's Avatar
All my PB stuff is new... one more reason I’d like to use it.
Carter
Old 08-03-2018, 08:37 PM   #6
nlped
nlped's Avatar
Thanks Keith, that’s good info. I’m leaning more & more towards “fitting” the ‘71 frame under the ‘77.
Carter
Old 08-03-2018, 08:37 PM   #7
nlped
nlped's Avatar
Seems to easy.
Carter
