Old 08-02-2018, 10:16 PM   #1
66K20
66K20's Avatar
K series shifter boots
My K20 has no boots on the floor shifters. I'd like to remedy this, but I do not know where to start or what parts I need.
I need boots for the transfer case shifter and the transmission shifter. Not necessarily looking for factory originals, but something that resembles the original set up would be great.
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
Old 08-02-2018, 10:24 PM   #2
Getter-Done
Getter-Done's Avatar
Re: K series shifter boots
https://www.brotherstrucks.com/73-78...tinfo/FSBT072/
84 Chevy K-20
Old 08-02-2018, 10:27 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Summit also has a big selection of shifter boots....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-03-2018, 09:29 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
The Truck Shop in Orange, CA has them also.
Old 08-03-2018, 11:20 AM   #5
66K20
66K20's Avatar
Thanks for the guidance so far. Found the needed transmission boot and retainer ring. I am not convinced I have found a suitable transfer case boot. The transfer case shift lever is practically laying on the transmission hump when in 2wd.
Old 08-03-2018, 02:48 PM   #6
61K10
61K10's Avatar
No one re-pops the t/f case one that i know of. One comes up on e-bay but big $$$. The trans never had one from the factory.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-03-2018, 09:04 PM   #7
Nanook
Nanook's Avatar
Sorry to hi jack this, but please clarify no boot on the shifter? Do you mean it's just open?
Nanook is offline   Reply With Quote
Old 08-04-2018, 12:44 PM   #8
61K10
61K10's Avatar
From the experts on here and my dad's 66 3/4t 4sp bought new in 66 had no trans boot. there is a seal that goes between the top of the trans and the trans tunnel.
1961 chevy K10
Old 08-04-2018, 02:15 PM   #9
Nanook
Nanook's Avatar
Nice...thank you.
That's what's on my K-10
Old 08-04-2018, 09:05 PM   #10
The Rocknrod
Moderator
Dont look on page 65 of the Truck Shop catalog. Dont do it.
Old 08-05-2018, 02:05 AM   #11
oem4me
Strange but true. No factory boot on the four speed. Foam seal only between floor and trans.
Old 08-05-2018, 01:13 PM   #12
61K10
61K10's Avatar
I have the floor shift boot on my tk but it's not factory and the 67-72 t/f case boot is not the same as 60-66. Don't know why they haven't re-poped it yet. No demand i guess.
1961 chevy K10
Old 08-06-2018, 10:12 AM   #13
66K20
66K20's Avatar
Thank you for the help.
I will get the sponge seal for the transmission but I need to find something for the transfer case. A lot of heat comes through the transfer case shift opening when going down the road.
61K10 - What boot are you running for the transfer case shifter?
Old 08-06-2018, 10:22 AM   #14
66K20
66K20's Avatar
Looks like the same offerings as LMC and Classic Parts.
I'd like to try the 67-72 boot, but nobody sells a retainer ring to go with it (at least I cannot find one).
Old 08-06-2018, 11:14 AM   #15
Short 3/4
From what I've seen on the two K trucks I've had, there may not have ever been a retaining ring, as no holes around either boot. What I did on my X-fer shiftier was install a round boot and put it down the hole far enough that the pleats of the boot hold it in. No ring is needed and it puts the Boot low enough that it will lay against the floor correctly when in 2 Hi. Not sure if the boots I used were correct, as had a couple different ones to choose from, but looks like you could cut down the tranny shifter from a later truck and make that work. Sorry no pictures, but not very good at posting them (have to get my wife to do it) but hope you get the idea, as it has worked good for me.
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 08-06-2018, 01:52 PM   #16
61K10
61K10's Avatar
the 67-72 t/f case one should work. Maybe make your own ring? water blast one? Put it under your mat or rug?
1961 chevy K10
