08-03-2018, 08:26 AM | #1 |
Should I be running a fuel additive?
I just replaced my intake manifold gaskets and it looked like this in the cylinder heads and intake manifold.http://67-72chevytrucks.com/vboard/a...1&d=1533298552
08-03-2018, 08:21 PM | #2 |
Re: Should I be running a fuel additive?
i run a small amount of marvel mystery oil in the fuel. not sure if it helps clean that but the fuel mileage is slightly better.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
08-03-2018, 08:50 PM | #3 |
I didn't know you could put that in the fuel system.I have put the seafoam in the minivan once and it pepped it up a little bit so I may that a try to.
08-06-2018, 07:53 AM | #4 |
What you are seeing is from the pcv system putting oil in the intake . These ls motors are bad at it . Since you have your intake off take a good look inside and you will oil pooled in the bottom .
Has nothing to do with the fuel . Additive will not fix that . You can see where the injector has been spraying and cleaning off in the head intake runner . There is a few ways you can combat it . Ls6 valley cover for one or a catch can. Do some searching and you will see what I am talking about . |
08-07-2018, 07:47 PM | #5 | |
