08-03-2018, 11:24 AM | #1 |
Fuel pump replacement?
‘67 GMC 250 L6 engine. Drove the truck to another town and took the opportunity to fill it up with premium non-ethanolic gas (it’s been a couple of months since the tank has been full - I’ve been buying local regular non-ethanolic a few gallons at a time). I get home, park it, truck has run fine the whole time...then the garage smells of gasoline. I don’t see any problem with the inlet or outlet lines on the pump, but the bottom of the pump has gas on it - not dripping off, just oozing out apparently.
So it’s the pump, right? I know replacing it is straightforward job - does anyone have any tips? Thanks!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
08-03-2018, 11:56 AM | #2 |
Re: Fuel pump replacement?
Very straightforward, the only semi-difficult part was trying to hold the pushrod in place when installing the new one. I used a tongue depressor sized piece of spring steel, which helped.
This guy used a screwdriver: https://www.youtube.com/watch?v=8XiuiyBAD8Q Last edited by ncpetersc; 08-03-2018 at 11:58 AM. Reason: added youtube vid |
08-03-2018, 12:16 PM | #3 |
20' Daredevil (Ret)
Dunno about L6 engines, but small-blocks have a threaded hole you can run a bolt into to hold the pushrod while you bolt the fuel pump on.
08-03-2018, 05:42 PM | #4 |
What carb are you running?
72 C10 lwb fleetside -stock 350/350 combo |
08-03-2018, 06:35 PM | #5 |
Rochester B...I rebuilt it a few weeks ago and the truck runs better than it has since I got it. It seems that over the 5 years I’ve had it, anytime I repair or rebuild something, a system-related problem crops up in a few weeks...replaced the radiator and the water pump quit...rebuild the carb and the fuel pump starts leaking....
But it’s all fun, in a slightly masochistic way.
08-03-2018, 07:16 PM | #6 |
But I have to ask... Why premium? Unless you're running high compression in that engine it's probably not giving you any benefit. If you haven't had detonation with regular, I would run that and fill the tank more regularly. A full tank helps prevent condensation.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-03-2018, 07:21 PM | #7 |
The pump arm on a L6 pump runs directly on the cam lobe. No push rod.
As with any leaking fuel pump, sniff the oil on the dip stick. The gas can run into the engine and you need to change the oil and filter. NOW. The old pumps i have pulled off had a tab riveted to the pump arm. I believe it to be a sacrificial metal to prevent wear on the cam pump lobe. The new Carter pumps don't have the tab. I spent time finding out that Airtex pumps still have the tab. i spent more time and gas getting an Airtex from the Truck Shop. I tested it before installation and found that the pressure dropped between successive pump strokes. I then bought a Carter from NAPA. It pumped to 4 psi on the first stroke and stayed there on every successive pump cycle.
'67 GMC 2500, 292, 4spd, AC |
08-03-2018, 09:42 PM | #8 |
i6 Fuel Pump replacement?
As mentioned, a new pump should set you right again .
Premium fuels because the bilge they're selling these days isn't anywhere near as good as regular was when your truck was designed and built . Yes, it co$t$ more but the low compression engine will run better anf less damage to carby, fuel pump diaphragm and so on . Those who are either cheapskates or don't know, will tell you no need to run premium fuels . Luckily these pumps are still made and not expen$ive to buy .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-03-2018, 09:43 PM | #9 | |
08-03-2018, 09:48 PM | #10 | |
08-03-2018, 09:50 PM | #11 | |
Re: i6 Fuel Pump replacement?
08-03-2018, 10:03 PM | #12 |
From An i6 Lover/Feeler/Enthusiast
Don't ever let anyone talk you out of that 250 ! .
Most are shocked when they ride in my '69, the engine is loosey-goosey but runs out very strongly because I keep it in sharp tune . I'd hot change the oil and filter the *instant* I finished the replacement of that old pump . Remember to hold the new pump up next to the old one, the out side isn't terribly important as long as the pipes connect but the lever *must* match excatly of the new pump won't last long . Spend some time looking at NAPA, Rock Auto etc. before buying a cheap Delphi part ~ GM sold off AC / DELCO some years ago so new Delphi stuff is in now way as good . Lots and lots of N.O.S. fuel pumps out there plus Airtex, NAPA and so on .
08-03-2018, 10:09 PM | #13 |
1967 GMC 250 CIC i6 Fuel pump
Let's see if I can add these Rock Auto part #'s :
CARTER M4503 {#6416502, 6440616} Mechanical Pump Info Crimp Style Sheet Metal Housing < Part image > $15.54 Add to Cart DELPHI MF0051 {#6416502, 6440616} Mechanical Pump Info 2 Line Pump; Stamped steel fuel pump < Part image > $15.86 Add to Cart AIRTEX 40446 Mechanical Pump Info One of our most popular parts See ? cheap and easy, just like my High School girlfriend.....
08-03-2018, 10:38 PM | #14 |
Who Changed This?
Don't knock cheap and easy! Just a waggle of the eyebrows, and it's on!
08-03-2018, 11:20 PM | #15 |
That makes the job too simple!
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-04-2018, 10:52 PM | #16 |
"Cheap & Easy"
I was driving down Figurative St. in South Central Los Angeles this afternoon, and boy howdy was there some smoking hot easy strutting , not sure how cheap but zowie .
08-04-2018, 11:32 PM | #17 |
API and every major automotive manufacturer disagrees with you, but what do a bunch of mechanical and chemical engineers know? Yes, non-ethanol is better for your fuel system, but premium fuel is a designation for higher octane, which most engines neither need nor derive any benefit from.
08-06-2018, 03:45 PM | #18 |
Got ‘er done! Thanks to all for the advice and entertainment!
08-07-2018, 09:47 AM | #19 |
Fuels In Older Engines
They don't in fact say that but who cares when you're not interested in facts, right ? .
