Old 08-03-2018, 01:25 PM   #1
Brandon66
Where to buy 1966 3 on tree shift linkage bushings?
Where have you guys bought the shift linkage bushings?
Brandon66 is offline   Reply With Quote
Old 08-04-2018, 04:51 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Where to buy 1966 3 on tree shift linkage bushings?
Do they look like these?:
https://www.ebay.com/itm/1955-1956-1...from=R40&rt=nc
Old 08-04-2018, 05:44 PM   #3
ray_mcavoy
We got some new ones for Dad's 66 from https://www.classicparts.com ... they call them grommets instead of bushings.
Their part number 91-062 fits the shift arm on the steering column. The ClassicParts listing says 2 required for 3-speed, but if I remember correctly, the shift linkage on Dad's truck only used 1 of these grommets on the 1st/rev lever. The 2nd/3rd rod had a metal bushing/sleeve built into the clamp assembly (where the rod adjusts) and didn't use a grommet.
Their part number 91-063 fits the shift arms on the transmission. The listing says 2 required and that means 2 for each arm (one goes on each side). So you need a total of 4 of these.
ray_mcavoy is offline   Reply With Quote
