1979 GMC Cab Rear Floor Rust
I bought a 1979 GMC Stepside Pickup and after further investigation i'm finding out the rust in the floor is a lot more extensive than i had originally anticipated. I'm finding thinner spots than normal on various areas on the back side under the seat. I already know the rockers, floor pans, cab supports and mounting rails are going to have to be replaced but i'm having a hard time sourcing replacement panel for the hump under the seat where the frame mounts through the cab. Has anyone else found an issue to this problem area?
#2 | |
Re: 1979 GMC Cab Rear Floor Rust
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
I think you're out of luck for that piece, but it shouldn't be to hard to find someone that could cut that section out of a parts truck and ship it to ya.
Thank you for your input. I've thought of finding a parts truck and possibly sectioning out the rear half of floor and re-welding it in. Its been hard to find GM SWB trucks for cheep cheep in this area that are not already completely rusted out. The frame is in good shape and the step side is repairable last guy started restoring but ran out of interest. Next step is to find swap meats or junk yard that haven't already been picked clean.
Another thought was to just get some metal bent and weld in a custom hump for the seat and fabricate a new seat bracket to fit. Is that an option? |
That would be an option for sure. Maybe you could share a pic of the area you're talking about, It might help get some different options
Here are a few pictures. It may not be as bad as i had originally thought. Perhaps a few patches welded in instead of the whole rear floor? Main problem is panel that holds nut for seat mounting bolts.
| Bookmarks |
