08-03-2018, 10:17 PM | #1 |
Two speed rear end in a P/U?!
Alrighty folks. new to the website and new to the trucks older than '72. (Save for a '55 3100 but that's besides the point.) Anyway. Looking at picking up a '63 C20 with a 4 speed and the 2(71?) small block. It's cheap, and halfway buried in the ground, but mark my words I'm gonna try and get it roadworthy. I know it's probably the least of my worries, but I was wondering if it was possible to stick a two speed rear end from a '58 dump truck under the pickup. It's only got a 4 speed, but it would be the only one around. If it is possible, how hard is it to hook up? Does it need vacuum or positive air pressure? Do I need to change the driveshaft or frame? And, is it possible to change the hubs on them, or would I have to stick with the huge effin tires and rims? Or, would there be a better option for it? Thanks for the help- in advance of course.
Chronically broke thanks to my '84 Scottsdale K20 |
08-03-2018, 11:48 PM | #2 |
60-66 Nut
Re: Two speed rear end in a P/U?!
The medium duty truck differentials are much larger physically than a Eaton HO52/72. Plus the high gear in those 2 speed differentials are a much lower gear than what is in the HO52/72. They do need vacuum to shift and yes you will be stuck with using the original hubs and 20" wheels. I see really no point is making this swap. If you want a higher gear in the C20, either change the trans to a OD trans, or change the differential to a 14 bolt or Dana 60 with higher gears.
08-04-2018, 09:58 PM | #3 |
X2^
08-05-2018, 01:32 AM | #4 | |
08-05-2018, 10:25 AM | #5 |
The 700R4 is popular, the latest version that still has the cable is probably the best. You would also need to do a cross member modification. Finding a 350 from an old P/U (year? ) with tranny attached would be a good score.
08-05-2018, 11:23 PM | #6 |
60-66 Nut
If you want to stay with a manual trans and use your C20 as a truck, a NV4500 would be the best choice IMO. If you want to go with an auto trans a 700R4 will work in a C20 if it is built right. If this is mainly a cruiser, then a NV3500 or a T5 will work for a manual trans. And again if a auto trans is desired a 700R4. The 4L80E is much heavier duty trans, basically a TH400 with OD, but they can be $$$ to retrofit. From a budget perspective, changing the differential will be much cheaper.
08-07-2018, 09:15 PM | #7 | ||
08-08-2018, 12:59 AM | #8 |
Put a road ranger gear splitter between the engine and trans.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-08-2018, 09:50 AM | #9 |
Moderator
Or you could go with a Gear Vendors Overdrive - http://www.gearvendors.com/cg2wd3s.html
