Old 11-15-2003, 12:06 PM   #1
veltex
veltex's Avatar
radio / stereo help
Hi all, dont really want to cut dash, is there any new stuff besides the custom autosound that will fit? also any photos of am/fm cd in dash install appreciated in case I go that route, will 6x9s fit in door on the flat vinyl of a 68? thanks
veltex is offline   Reply With Quote
Old 11-15-2003, 12:47 PM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
go to www.customaudiosound.com or check out this thread http://67-72chevytrucks.com/vboard/s...hlight=kenwood I had the kenwood at one time and it sounded decent. As far as 6X9s I am not sure do a search for 6X9 and see if anyone has done it.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 11-15-2003, 03:30 PM   #3
Gee_Emm
You could do a underseat or glovebox set up, alot of head units you can get remotes for too.
Gee_Emm is offline   Reply With Quote
Old 11-16-2003, 12:56 AM   #4
veltex
veltex's Avatar
ttt
Old 11-16-2003, 12:30 PM   #5
Mike C
Mike C's Avatar
This is a subject that just never ends! Many different dual shaft knob units will fit. If they are a little small, an oversize faceplace can be made from sheetmetal that goes behind the radios faceplate. I did this for a few years, then hacked away! I have not regretted that for a minute. But as far as speakers, I cut my door PANELS and not the bottom of the door. This also requires holes in the door behind the panel, but to return to stock only requires replacing the panel. It also sounds awesome. I have 4" separates in the door panels with their crossovers mounted on the kick panels, a 10" free air sub under the passengers side of the seat in a "box"(the back is open to the floor), a crossfire 4x100 bridged 2x100 1x200, and an Alpine 6 disc changer. This is very unobtrusive and sound is excellent. I have a stack of old Alpine DIN style pullout head units. I can swap from one to the other and leave them in the house if my vehicle will be outside overnight. Also handy since my boat has the same sleeve, no need to leave the stereo in the truck at the ramp!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-17-2003, 11:22 AM   #6
veltex
veltex's Avatar
stereo
thanks mike c , I am leaning towards cutting dash but not doors too. I dont need a killer stereo just enough to sound nice, that has easy to use buttons, I like Alpine stuff, and will probably go that route, would like to get away with one set of speakers for now, do you think I can 6 1/2s in the door panel below window crank? anyone?
Old 11-17-2003, 11:32 AM   #7
slam33
slam33's Avatar
I have mine in the center consol along with my changer. I use the on/ off knob on the AM radio to switch on the power to the whole system. Works great.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 11-17-2003, 11:55 AM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Thumbs up
Originally posted by slam33
...I use the on/ off knob on the AM radio to switch on the power to the whole system. Works great.
That's a really cool idea
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-17-2003, 12:19 PM   #9
REDWHITE402
Guest
Posts: n/a
Kenwood makes a high output with shafts and outputs for a c/d changer. Great unit..
Old 11-17-2003, 12:20 PM   #10
REDWHITE402
Guest
Posts: n/a
scroll back a week or two and see pictures of it
Old 11-17-2003, 12:32 PM   #11
gonebad2
Merciless Butcher
gonebad2's Avatar
Check out www.roddoors.com They have all sorts of options for mounting stereos and speakers in 67-72 Chevy Trucks. I've purchased stuff from them and have been very satisfied.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-18-2003, 12:29 AM   #12
Mike C
Mike C's Avatar
I don't think 6 1/2's will work. Even the lowest profile. Because the speaker actually goes in a part of the door where the window is. You just have to pull a panel and approximate its location. The grill needs to clear the window crank handle as well, but the tweeter does not since it is flush mounted. I slightly tweaked my window cranks as well for more clearance.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-18-2003, 01:16 AM   #13
Hooter
My other Love
Hooter's Avatar
This is my setup. A Panasonic cd player, two ADI 6 inch subs in ported boxes, a Kenwood 4 channel amp with Kenwood components, I did cut my dash and my doors, but it's my truck and will always be mine till I die so I didnt care
If are not interested in cutting a hole in your dash I do have a few shaft cassette players, with digital tuners, preouts and a couple with auxilary ins, so you can plug a cd player in or run a RF mod cd changer, PM me if interested
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-18-2003, 04:52 AM   #14
BUXMAN66
go bucks!
6.5" will work w/ kick panel's from customautosound.just installed mine,waiting for the "stealth" under seat enclosures from brother's that are on b/o also made by customautosound.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
