WTB looking for usable, reasonable, complete HEI distributor for Inline 6
wanting to convert to HEI (250 inline 6) thanks.
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold) 1985 K30 Dump Truck 1986 Jeep CJ-7 1955 2 door 210 post |
![]() Join Date: Jul 2001
Re: WTB looking for usable, reasonable, complete HEI distributor for Inline 6
Just a suggestion and a thought but you might consider doing a Petronix ignition conversion. They make a 6 cylinder unit for both 6 volt and 12 volt systems. I converted my '71 4x4 using original stock GM points distributor and stock cap. Worked out really well since the V8 4x4 engine sits further back on the frame I did not have room for a large cap HEI distributor. This solved the problem and gives a stock looking engine compartment. Just some thoughts.
Good luck on your project. ![]()
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Thanks IronHorse ! I do like the Petronix stuff, but this is a basket case project and I do not have the (or any ) distributor assembly at all... just thought getting an hei unit would be quickest and easiest. And would rather have good used than chinese....
If interested I think my BIL, old wagon, has a 6 cylinder distributor from a '67 GMC he is parting, that would be a 12 volt system. Should be compatible to your square body I would think. Might contact him, just a thought.
I've got an msd distributor and coil I bought for my 292. New in box. You interested in something like that?
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
Pm
Pick up a Skip White on evilflay. Drop in no muss no fuss. don't forget to put on good wires, replace the resisot wire, and up the plug gap.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
