08-05-2018, 04:46 PM | #1 |
A/C not working on high speed fan setting
Worked fine for the past several years. Blows fine on low and medium settings, just quits blowing on high. Suggestions are appreciated.
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
08-05-2018, 05:25 PM | #2 |
Who Changed This?
Re: A/C not working on high speed fan setting
Seems like the switch spends most of its life in the high position. I vote the switch is bad. Easy enough to check.
08-05-2018, 09:04 PM | #3 |
Moderator
Check your ground on the relay, located behind the glovebox as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-05-2018, 09:15 PM | #4 |
Mine just did the same thing. I replaced the relay, problem solved.
08-06-2018, 08:32 AM | #5 |
Thanks for the responses. I ordered a new NOS switch. I'll update the thread once I solve the issue.
08-06-2018, 08:44 AM | #6 |
Pull the high speed fan relay from off the top of duct work behind glove box. The coil on it's probably burnt into rather than it being a fan switch problem. 2 screws to remove and then you'll know
Paulo Jr @ GMCPauls |
08-06-2018, 10:52 AM | #7 |
Who Changed This?
Does high fan speed use the relay? I thought that high speed was direct battery voltage, and didn't use a resistor.
08-06-2018, 11:10 AM | #8 | |
Paul Jr @ GMCPauls |
08-06-2018, 04:35 PM | #9 |
Who Changed This?
OK, I see. My switch was stuck in the "off" position, so the choice of what to replace was obvious. Good to know about that relay. Thanks for the explanation!
08-06-2018, 10:05 PM | #10 |
I have same problem. Best way to access the relay?
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
08-06-2018, 11:46 PM | #11 |
If you can contort your arm, and reach screws on the top, you don’t have to remove the glove box. Otherwise, just save yourself the frustrations and pull the box liner and then you will have easy access to the relay. It’s right on the far right side from the seated position.
Remember to clean the ground wire that will be under one of the screws. |
08-09-2018, 11:10 AM | #12 |
Replaced the switch and solved the problem. The switch was burnt at the M connector but ohm's checked bad across all terminals. It burned the plug but it was still useable. Looked to be the original switch. Replaced with a new GM part ordered off eBay. Here is the link to the new switch.
https://www.ebay.com/itm/GM-1965-66-...53.m2749.l2649
04-09-2020, 04:52 PM | #13 |
As Paul said, In the last two trucks I had high speed issues with, it was the relay. In one truck, somebody took the relay out and never put it back and the other was poor ground.
I just now worked on one that the switch would not go on high speed. Somebody had put a screw with a head in the bottom hole, and the switch could no too to the high position.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
04-09-2020, 09:06 PM | #14 |
Old member
I have fixed I don't know how many fan switches that either quit working are they fall a part. Not a lot to them once you take it a part and know how the parts go back together. Clean the copper contacts inside good and put some electrical grease in it and it works like new again are at least the ones I've done have.
06-16-2020, 09:02 AM | #15 |
Ok. before I start drinking again I hope someone can figure my problem out. My fan never worked on high but i'm not a real fan of AC and our cabs are small so never really needed it. With Covid 19 and self isolation a man has to do something so I thought that I would get into solving the problem. Fan works on low and medium, nothing on high. I did the 12 volt test at the relay and have power there. Here is the problem, when I remove the ground wire from the relay, the fan motor works on high. Now low speed is low and medium seems to be medium but when I switch to high the motor comes on but the rpms drop a bit from the medium position. I've read many articles about making sure the ground is in place properly but none ever say take the ground off. Hope someone has the smarts to figure this out for me. Dam Covid19 anyway. Solve my problem so we can both have a good day. Stay safe eh. Ron
06-16-2020, 02:06 PM | #16 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-16-2020, 07:02 PM | #17 |
I just fixed the same problem with mine. Worked on the high speed, but I smelled something getting real warm. took the switch apart clean and greased it. Cleaned the connectors and pulled the plug apart and cleaned everything. Works great now, just the plastic at one of the connections is a little warped from being overheated.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
