08-05-2018, 06:32 PM | #1 |
Builders tag. Does anyone know these codes?
I lost the builders tag or builders sheet or whatever it is called. Below is the only picture I can find that is readable. the truck is a 1984 c10 1/2 ton 2WD 3 speed on the column and originally had the 250.
I can figure out the first two lines on the second column. I assume it says fleetside and 4.1 250L6. Does anyone know what the other lines are? or could be? maybe there is a cheat sheet so to speak to tell me what they mean. In case this inst readable I wrote out everything on a sheet of paper. I will post it next
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
08-05-2018, 06:43 PM | #2 |
Re: Builders tag. Does anyone know these codes?
here is what is visible from the picture.
If you just know what options that would show in those lines would be great as well!
08-05-2018, 07:33 PM | #3 | |
E63 = Pickup Box - Fleetside LE3 = Engine - L6/250 - 2 BBL - Varajet NA6= High Altitude Performance Emissions System XYP= ? ZYP= ? Z53= Gauge Package - Voltmeter, Oil Pressure & Coolant Temp 77W= Interior trim combination - Dark Maple (W) |
08-05-2018, 09:07 PM | #4 |
Nice thank you! The interior color of dark maple is interesting. I wasn’t aware that was an option. I figured it was burgundy. That’s what most replacement parts look closest to it.
For the xyp and zyp lines do you know what type of option is usually listed their? Like brake systems or rear end gear ratio?
08-05-2018, 10:06 PM | #5 |
Xyp and zyp are probably the tire size front and rear mine are 225/75r15and listed as xlx and zlx with ylx as the spare in a 225/75r15. Gq1 is probably a 2.73 rear
08-05-2018, 10:30 PM | #6 |
That would make sense on the tire size. Thanks!
08-05-2018, 10:33 PM | #7 |
Here’s a big list of rpo codes.
You might find what you need in there. https://www.marshu.com/images-websit...-car-codes.pdf Your original tire size could have been 195 75 15’s. My old 84 had that size originally. |
08-05-2018, 10:50 PM | #8 | |
But I wonder what the standard rear end gear ratio was. In this list the rpo for a 2.73 is GS1 among several others but GQ1 is the only standard ratio line it seems. And it doesn’t actually give a ratio. If 2.73 was standard why bother giving it several othe rpo codes?
08-06-2018, 12:26 AM | #9 |
Moderator
X, Y, Z prefix are mounting positions.
YP suffix is 195/75R16 radial tires XYP is 195/75R15 Front YYP is 195/75R15 Rear ZYP is 195/75R15 Spare GM was fairly consistent about these RPO codes... My 2005 2500HD came with LT245/75R16 Load Range E tires on PY0 Aluminum wheels and a steel spare. XGK-TIRE FRONT LT245/75R16/E BL R/PE ST OOR(9591214) TIRE(XGK) YGK-TIRE REAR LT245/75R16/E BL R/PE ST OOR(9591214) TIRE(YGK) ZHH-TIRE SPARE LT245/75R16/E BL R/PE ST ALS(9591207) SPARE TIRE(ZHH)
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
08-06-2018, 11:35 AM | #10 | ||
The optional ratio noun name is reported because it always stays the same (ie, GU6 = 3.42; GT4 = 3.73). https://www.gmheritagecenter.com/doc...olet-Truck.pdf The standard axle ratio for your configuration was 2.73:1 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-06-2018 at 11:49 AM. |
08-06-2018, 11:43 AM | #11 |
It's called a SPID label (Service Parts ID label).
If you would like to have a new one made you can contact site member Jeff (chipflyer) and he will make you an authentic looking one. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-06-2018, 12:37 PM | #12 |
Nice! Thank you! I may talk to him when I get to putting final touches on the truck.
08-06-2018, 12:44 PM | #13 |
Isn't it kind of odd for an 84 to have the SPID on the inner fender?
08-06-2018, 12:50 PM | #14 |
My 84 GMC K1500 has it on the driver’s side inner fender also
08-06-2018, 12:53 PM | #15 |
08-06-2018, 11:40 PM | #16 |
Moderator
I've seen them in either location on the same Model Year trucks. I figured it was assembly plant dependent. Keith may have more insight on it...
08-07-2018, 04:51 AM | #17 |
I always enjoy seeing this kind of information being sleuthed out. hatzie, Keith, thanks.
08-07-2018, 11:54 AM | #18 | |
K
