08-06-2018, 12:20 PM | #1 |
Fuel Pump Info
Can anybody here tell me if a fuel pump from a Vortec engine equipped truck or say a TPI Camaro will work in my 88K5?
I am getting ready to install my 350 Ramjet in my truck & I am gonna need a lot more fuel psi than the stock pump delivers. My MEFI manual says that any Multi Port GM or Vortec Fuel pump will provide the 40-45 psi needed. I may have to Piggy Back another pump inline with the stock one to make it work. Thanks |
08-06-2018, 03:35 PM | #2 |
Re: Fuel Pump Info
When I converted my 77 to Sniper EFI I used an '89 K5 sending unit from rock auto (Spectra part #FG12L). To that I added Walbro fuel pump part #GCA758-2 from Summit. Wiring pigtails matched up perfect. No splice required as is implied by the product description photo on summit.
Spectra SP1151 may suit your requirements also.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD '77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD rust repair on the '77 http://67-72chevytrucks.com/vboard/s...d.php?t=740291 |
08-06-2018, 11:08 PM | #3 | |
Re: Fuel Pump Info
Thanks! |
08-08-2018, 11:23 PM | #4 |
Re: Fuel Pump Info
Hey mickeykreg what did you do for a fuel filter? i doubt that the stock TBI filter handles 45 PSI or will it?
Thanks! |
08-11-2018, 12:09 AM | #5 |
Re: Fuel Pump Info
Sorry about the delay. I used summit part number SUM-230131 in line.
08-12-2018, 12:40 AM | #6 |
Re: Fuel Pump Info
OK thanks.
RockAuto shows the same filter for both the TBI K5 & the TPI Camaro. |
