08-06-2018, 12:35 PM | #1 |
More Parts from a 72 3/4T LWB
I am listing the rest of the parts from the 72 3/4 Ton LWB
If you need better photos, I can post 4 Blade fan w/spacer -$10.00 Single groove water pump pulley-$5.00 Single groove crank pulley-$5.00 Set of top radiator brackets-$5.00 Alternator brackets(upper & lower)-$15.00 Washer fluid bracket-$5.00 1 Horn(works)-$10.00 Hood latch w/good spring-$5.00 L & R hood hinges(little tight needs oiling)-$10.00 Complete Z- Bar,frame bracket, adjusting rod,clutch pedal rod, lower return spring(sbc V-8 set-up)-$30.00---SOLD Complete throttle pedal-$10.00(manual)---SOLD Throttle cable, carb bracket(Q Jet)-$5.00---SOLD Complete wire harness (engine bay,interior,rear lights harnesses, only goes back to the end of the frame)fuse box included on interior harness-$10.00 per harness or $15.00 for all (no interior light wire)---SOLD L & R sbc engine frame towers- $15.00 for set Right side only- exhaust manifold air deflector-(mounts on top of frame for the cooling of the exhaust manifold)-$20.00 Manual trans lower inspection cover and shield(2-pcs)-$20.00---SOLD L & R wiper arms-$10.00 for the pair Wiper transmission w/attachment for motor-$10.00 (serration's good) Original thermostat housing-$5.00 Clutch fork-$5.00---SOLD 2-Chevy grill emblems-$15.00 per emblem L & R mirror arms-$10.00 for the pair--SOLD L & R Headlamp bezels-$20.00 for the pair 2-Custom 20 emblems-$15.00 for the pair 2-350 engine emblems-$15.00 for the pair 1- Med bronze gas cap-$10.00--SOLD L & R door hinges( 3-tight, 1 loose)-$10.00 per door Nice manual high hump (great shape) rubber no good-$10.00 Complete E-Brake assy(black handle gone) good spring, W/cable clamp-$15.00 Good E -brake cable from E-brake assy.to spreader cable (comes w/ the front cable and right front frame to cable rod, 2 frame guides/rod, 2 cable connecters,-$20.00 Complete brake and clutch pedal assy. w/good return spring-$10.00---SOLD Complete power brake unit (core only) includes all brackets and proportion valve(can separate)-$20.00 Manual speedo cable-$5.00 White ash tray w/ball bearings, no bracket-$10.00 Steering column(manual) core parts only -$10.00 L & R black sun visors w/ holders-$25.00 for the pair--SOLD Inside rear view mirror w/mount(some hazing) night & day settings work-$10.00 5-Seat belts (3 female, 2 male) 1 is the male from the retractable(the retractable is bad) plus 1-black retractable cover (all have the tag from 72)-$50.00---SOLD L & R seat tracks(left handle needs welded back on,broke about 1/2 way up)-$40.00 Right side Tail gate hinge assy. L & R tail gate trunnions(good shape)-$35.00 Original oil pressue line & block adapter-$10.00 L & R door striker plates-$5.00 each L & R fresh air flaps and hardware (rubber ok)-$10.00 Heater core housing-$5.00 Any Cab cuts-$20.00 and up Front bumper brackets(4)-$15.00 Front sway bar,1.100 dia.(includes frame brackets)-$20.00---SOLD 4.10 open rear gear-$40.00--SOLD HO52 rear cover-$5.00--SOLD Any frame cuts-$20.00 and up
https://www.paypal.me/Dwayne77 Last edited by olschool; 08-14-2018 at 06:17 PM. Reason: adding text |
08-06-2018, 12:57 PM | #2 |
Re: More Parts from a 72 3/4T LWB
I am interested in all the seat belts, sun visors, and the rear view mirror. Can you please post additional pictures or text them? I’ll send you a pm with my number. Shipped to 90713. Thank you.
08-06-2018, 01:18 PM | #3 |
Interested in the high hump, can you post pic or send thru pm?
08-06-2018, 02:16 PM | #4 |
What shape is steering wheel in and horn stuff to go with.?? And how much? Or does it go with column? Let me know. Pictures please. Thanks.
And I will take mirrors. They come complete? Shipping to 87107. Thanks. Pm sent. Last edited by painterljp; 08-06-2018 at 02:31 PM. Reason: More stuff |
08-06-2018, 02:33 PM | #5 |
KV63-sent pics to cell#
jhuerta81-pics posted,I checked with usps the shipping cost is $46.00(thats crazy) painterLJP- wheel is no good,horn button is no good,I have not looked at the horn mech. Thanks Dwayne
https://www.paypal.me/Dwayne77 |
08-06-2018, 03:10 PM | #6 |
Ill pass on hump, since shipping is crazy
08-06-2018, 03:34 PM | #7 |
Money sent to PP. Thank you.
08-06-2018, 07:04 PM | #8 |
Are seat tracks bench? Will buy if buckets
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
08-06-2018, 07:04 PM | #9 |
I would like the med bronze gas cap
08-06-2018, 07:07 PM | #10 |
HO rear cover as well I will buy
08-06-2018, 07:09 PM | #11 |
Ok. Guess just a quote and pictures of mirrors. To 87107. Thanks. Glass is no good or what?
08-06-2018, 10:03 PM | #12 |
1968k20-- med bronze cap,Ho52 cover yours, seat tracks are bench. I need your zip. Dwayne
Paintljp-- Did you get the pics of the mirrors? Dwayne
08-06-2018, 10:33 PM | #13 |
Got them. Let me know shipping total. Hopefully not stupid on shipping.
08-06-2018, 10:56 PM | #14 |
Shipping on z-bar hardware, transmission inspection covers, clutch pedal assembly, and clutch fork to 66032? Also interested in transmission bellhousing. Thanks!
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
08-06-2018, 11:02 PM | #15 |
Paypal sent. Thank you.
08-06-2018, 11:09 PM | #16 |
I will get you a quote on shipping for the parts you listed tomorrow morning, The bell housing is still in the truck, I would not be able to remove the bell housing until thursday to get a quote on shipping. The cost of the bell housing would be $20.00 plus shipping.Thanks Dwayne
https://www.paypal.me/Dwayne77 Last edited by olschool; 08-06-2018 at 11:13 PM. Reason: added text |
08-07-2018, 04:02 PM | #17 |
I got dibs on the 4.10 open gear set if it is not spoken for. Can you please send me a pic and a shipping estimate to zip code 42349! I know it wont be too cheap. We can ship to a business address if that helps.
Thanks, BluegrassChevy |
08-07-2018, 04:08 PM | #18 |
I would also be interested in a price and shipping to 42349 on the z bar, clutch pedals, linkage, clutch rod, fork, etc. if Sand Wrench doesnt take it.
Thanks, BlugrassChevy |
08-07-2018, 05:19 PM | #19 |
I am interessed for the complete wiring. Would you ship to Canada ?
08-07-2018, 05:31 PM | #20 |
I would not be able to get the 4.10 gear out until tomorrow to get a shipping quote Thanks Dwayne
08-07-2018, 05:34 PM | #21 | |
I have member dauderm1 interested in the wiring harness I will let you know Thanks Dwayne
08-07-2018, 08:19 PM | #22 |
I'm in for the throttle pedal setup. Thanks, Curt
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
08-07-2018, 08:39 PM | #23 |
I would need your zip code for a shipping quote. Thanks Dwayne
08-07-2018, 11:57 PM | #24 |
Sorry, you would need that info It's a residential address 80214.
08-08-2018, 09:11 AM | #25 | |
Shipping cost is $12.68 Let me know, Thanks Dwayne
