AS blowing at feet
hi all,
my ac works but air is cold only at your feet. I think it's the diverter. Any ideas to source parts for this?
1990 suburban r1500 k 350 2wd |
#2 | |
Re: AS blowing at feet
Make sure the vacuum hose coming from the firewall is connected and not broken in the engine bay. You can take a hand vac pump and test it there to make sure you can get the vents to operate. |
OutOfMyMind & I'llNeverKnowWhy
Check to see if this plastic hinge is broken. I have to replace mine every few years.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
Re: Ac blowing at feet
Looks like the hinge is bad. Where do you get a replacement?
Check out this thread, should have most of the info you need: http://67-72chevytrucks.com/vboard/s...d.php?t=460942
The white thing connects to the hot/cold door. I think your original problem is the defrost/heater flapper. |
Ok. On closser look it looks like this part is broken
Justin, you're showing me the same image. Sorry, couldn't see it on my phone. So where do we get that hinge? http://photobucket.com/gallery/user/...NjEwMQ==/?ref=
1990 suburban r1500 k 350 2wd Last edited by snowball; 08-07-2018 at 02:40 PM. Reason: added details |
Part #3018715. Come in 5 packs from the GM dealer. There is a lot of pressure from the vacuum motor and they always seem to break in the same thin part of the plastic.
someone needs to machine those out of billet!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
That would be a help. The plastic always breaks in the same spot. Its quite thin and over time the plastic likes to get brittle.
Unfortunately 3018715 is discontinued.
Once I get my hands on one of these I'll laser scan it and post it on thingiverse so it can be 3D printed in the future. Any other ideas where to get one?
Classic Parts has them. I think I bought 3 of them when I needed one, but now I can't find the other two I did not use. Considering the high cost of shipping, it is best to buy more than one.
I found info on here about making one out of metal. I had a small scrap piece of u shaped aluminum and used a grinder, drill and file to make this one. Not pretty but does the job.
| Bookmarks |
