Old 11-15-2003, 03:55 PM   #1
Olden Days
Living In The Past
Olden Days's Avatar
does Big block = high hump?
My search came up showing that big block trucks came with high hump cab. Does this mean if I want to put a big block in a low hump truck it wont work without cutting out the low hump? Or can I still shoe horn it in there? thanks...... jerry
Olden Days is offline   Reply With Quote
Old 11-15-2003, 04:23 PM   #2
junkyardjohn
junkyardjohn's Avatar
YOU CAN SHOEHORN A BIG BLOCK WITH A T-400 IN A 67-72 TRUCK WITH A LOW HUMP, BUT IT'LL BE TOUCHING THE HUMP. A FEW MEMBERS WILL TELL YOU "OH SURE LOTSA ROOM" WELL MAYBE IT'LL FIT WITH A T-350, (I'VE NEVER TRIED)BUT G.M. HAS NEVER MADE A BIG BLOCK WITH A T-350 BEHIND IT, OR PUT A BIG BLOCK IN ONE OF THESE TRUCKS WITH A LOW HUMP. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-15-2003, 04:42 PM   #3
Olden Days
Living In The Past
Olden Days's Avatar
Thanks ....I have a th400 already that I thought I might use, but was also considering finding a 700r4. Are they any bigger outside dimension than the 400?? thanks.....jerry
Old 11-15-2003, 05:24 PM   #4
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
id like to know more about this also
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-15-2003, 06:02 PM   #5
Truck Hippy
Truck Hippy's Avatar
Every factory BB truck I have seen had the high hump. I had a 70' 1/2 ton that I put a 350/400 turbo in and I didn't have trouble with the low hump hitting the trans. I have a buddy that junked out a 72' GMC that was a 307/3-speed manual, 1/2 ton truck but It had the high hump.
Truck Hippy is offline   Reply With Quote
Old 11-15-2003, 06:11 PM   #6
frost89434
frost89434's Avatar
I just ran into this problem this last week. I have a 454 with a t350 behind it. It did fit but it hits the floorboard. So I cut out the low hump and put in a high hump. Now no more problems. JIM
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 11-15-2003, 10:01 PM   #7
miket
miket's Avatar
Mine was a original 350/t350 truck....low hump.....it now has a 502 and T400....no problem.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 11-15-2003, 10:45 PM   #8
ira ashley
BB WITH LOW HUMP
I JUST PUT IN A 402 WITH A 400TH WITH A LOW HUMP, NO PROBLEM! YOU MUST USE THE CORRECT TOWERS TO MAKE IT FIT CORRECTLY.........IRA
ira ashley is offline   Reply With Quote
Old 11-15-2003, 10:55 PM   #9
frost89434
frost89434's Avatar
I used the correct towers!!! And it still hit the floor.
Sparks, Nevada
Old 11-15-2003, 11:06 PM   #10
67cst
i love summertime
67cst's Avatar
i have a th400 with the low hump in the 67, its a real snug fit, maybe 3/8s of an inch gap, but ISNT touching..sure tight though, if it were any closer id concider a high hump
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 11-15-2003, 11:13 PM   #11
Orence1
Orence1's Avatar
I have a 402 with a TH-350 and I have adequate room in my 72 LWB Cheyenne (small hump). I do have the correct 72 BB towers and motor mounts.
Orence1 is offline   Reply With Quote
Old 11-15-2003, 11:27 PM   #12
ira ashley
BB WITH LOW HUMP
I HAVE RESTORED THIS TRUCK FROM TOP TO BOTTOM NEW CAB MOUNT & ALL. MAYBE THE PROBLEM WITH EVERYONES TRANNY HITTING IS WORE OUT CAB BUSHINGS. I CAN PUT MY HAND ALL THE WAY AROUND THE 400TH TRANNY. IF YOU USE THE WRONG TOWERS IT WILL MAKE THE FRONT OF THE MOTOR BE UP NOT LEVEL WHICH WILL CAUSE THE TRANNY TO HIT THE FLOOR. I USED THE 72 TOWERS & MOTOR MOUNTS WHICH ARE FLAT. MINE WORKED GREAT.........IRA
Old 11-15-2003, 11:29 PM   #13
frost89434
frost89434's Avatar
I used the 72 style too. And I also have new cab bushings. JIM
Sparks, Nevada
