Old 11-15-2003, 04:08 PM   #1
CraigS
Non-AC Heater Fan SW Hookup
Does anyone have the schematic for the hookup of the heater fan switch? I know there are 4 wires, but there is no plug (on mine anyway). Trying to figure out which wire goes to which terminal on the switch. thanks..........
72 GMC K20, 454, TH350
00 GMC Yukon
66 Ford Bronco
CraigS is offline   Reply With Quote
Old 11-15-2003, 06:33 PM   #2
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
this might help
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 11-15-2003, 06:37 PM   #3
jorgensensc
jorgensensc's Avatar
Also try this link:
wiring diagrams
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-15-2003, 08:23 PM   #4
cali_surfer
cali_surfer's Avatar
I'm not sure if this will help you, but I put in a Old Air A/C kit. I didn't have the plug like you, so I found out the color code. I'm not sure the stock wiring is the same color as the Old Air kit, but here goes:
Low - Yellow
Medium - Red
High - Orange
Blue - Power
On the switch it will probably have letters next to the prongs, such has "L", "M", or "H" mine did but then again I have an A/C switch.
Good luck
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
