Old 08-09-2018, 03:34 PM   #1
68ihscout
Harmonic b
The threads on the crank are stripped ,used a chaser to clean it up and i was able to get the harmonic almost all the way before the threads gave ,i am about 1/8th inch out any suggestions. I am also wondering the old seal on the timing cover was not absolutely flush ,the new one we did is would that maybe be the difference in the shiny part isee.,, any thoughts are greatfuly apreciated.
68ihscout is offline   Reply With Quote
Old 08-09-2018, 10:44 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Harmonic b
Do the pulleys line up where it is now? Post a picture of where the end of the crank is in the balancer.
LockDoc
Leon
Old 08-10-2018, 09:39 AM   #3
68ihscout
LockDoc
I will have to educate myself on how to post a pic ,,i have not try to install the pulleys yet but i will do a test fit this weekend , thank you doc for the great idea !!
Old 08-10-2018, 09:49 AM   #4
68ihscout
I took a pic hope it shows
Old 08-10-2018, 10:25 AM   #5
LockDoc
LockDoc's Avatar
Re: Harmonic b
Picture looks good, now take one from the front.
LockDoc
Leon
Old 08-10-2018, 03:44 PM   #6
68ihscout
LockDoc
As soon as i get home from work ill take a frint picture. Thanks doc
Old 08-10-2018, 10:53 AM   #7
RichardJ
Re: Harmonic b
Were you trying to pull the balancer on with the original balancer bolt?
I don't know how you were trying to install the balancer, nor do I have any way of knowing the condition of the threads remaining. All I'm offering is how I install balancers and what I would do to attempt to finish your installation.
That bolt is always too short for installation purposes. Try to clean the threads up again. Find an extra long bolt that can be threaded in, all the way to the bottom of the hole. Assemble a large, extra fat washer(s) to push against the balancer. Next is a stack of high quality thrust washers. Preferably with a couple of polished stainless washers and a few drops of oil. Next is a nut that you will be turning to push the balancer in.
When you're turning a bolt that is being used as the installer, it is only pulling on a few threads at a time and wearing away the threads as it is turning. A long bolt that isn't turning, is pulling against all of the threads, the full length of the hole.
I have an assortment of old bearing and gear pullers. Among those pullers I can always find the right center bolt with the right threads that I can turn into an installer for a variety of engines.
The balancer pictured is a photo I posted on a Corvair forum, but you should be able to see that the nut is doing all the work and it is turning against oiled thrust washers.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 08-10-2018, 03:44 PM   #8
68ihscout
i bought and used the correct tool for the job ,the one that shows on your picture..
Old 08-13-2018, 01:20 AM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Harmonic b
I'm installing one myself soon. Here's an excellent video, this guy is real good, though he seems to have more faith in experience than torque wrenches https://www.youtube.com/watch?v=R7BuijqjcUk
Not saying you didn't, but the bolt inserted into the crank has to bottom out. Otherwise you're tearing up threads as you tighten the balancer.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-13-2018, 07:50 AM   #10
Grumpy old man
Grumpy old man's Avatar
Re: Harmonic b
Here is an explanation of why you apply grease to the back of the crank seal , It's just a safety measure but if the spring does come off when your replacing the seal with the timing cover on the engine it eventually will end up in your oil pan and nobody wants pieces of spring steel getting sucked up into your oil pump . I've seen it happen . This is why I pull timing covers to replace crank seals .
https://www.youtube.com/watch?v=WOfOHMI6Wnc
https://www.youtube.com/watch?v=1MzHlqQFHcs
Grumpy old man is offline   Reply With Quote
Old 08-13-2018, 09:44 AM   #11
68ihscout
funny thing is ,that spring came flying off as soon as we took the cover off , and yes nobody wants pieces of steel flying around in there
Old 08-13-2018, 09:45 AM   #12
68ihscout
Old 08-24-2018, 03:47 PM   #13
68ihscout
Re: Harmonic b
Well folks got the truck started sounded good but now we have hemorrhage from the bottom of timing cover /oil pan meet ,would it be safe to say its the oil pan gasket ,i did replace the half moon one but i guess it did not seat correctly ,thanks again
Old 08-24-2018, 04:30 PM   #14
geezer#99
geezer#99's Avatar
Re: Harmonic b
Did you use the right one?
There are two.
Different thicknesses.
geezer#99 is online now   Reply With Quote
Old 08-24-2018, 05:04 PM   #15
mrein3
mrein3's Avatar
Re: Harmonic b
Back to your messed up threads in the snout of the crank.
Google "Bottoming Tap". You can usually cut a few more threads in there with one.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-24-2018, 10:03 PM   #16
68ihscout
I did run a 7/16 20 in there , the initial 1/4 inch threada were bad just deep wnough for the bolt to slip ,i got a longer bolt and cut it down a bit and it was able to grab enough to tighten ,its all good now .
Old 08-24-2018, 10:00 PM   #17
68ihscout
There are two.
I used the one that came with the timing cover gasket which was the right one ,i did put them side to side and they were the same ,.
Old 08-24-2018, 09:56 PM   #18
garyd1961
Re: Harmonic b
I've seen people drill out a crank with stripped threads and rethread it for a larger bolt, I believe it was a 3/4 bolt.
garyd1961 is offline   Reply With Quote
Old 08-24-2018, 10:05 PM   #19
68ihscout
Its all good bow ,but if i have to take it off again ill have to go that route.
Old 08-24-2018, 10:02 PM   #20
geezer#99
geezer#99's Avatar
Re: Harmonic b
Did you lower the pan when you put the timing cover back on?
Old 08-25-2018, 08:35 AM   #21
68ihscout
Oh oh ,i most certainly did not ,smh
Old 08-25-2018, 08:44 AM   #22
geezer#99
geezer#99's Avatar
Re: Harmonic b
Oh, oh is right.
Likely knocked the gasket outta place.
There’s two ways to fix it.
One is drop the front of the pan about 1/2 inch so the timing cover gasket stays in place.
Two is leave the pan alone and modify the cover bottom channel.
Like this. Pic-in here and explanation.
https://forums.iboats.com/forum/engi...ng-the-oil-pan
Old 08-25-2018, 08:54 AM   #23
68ihscout
Oh, oh is right.
Old 08-25-2018, 09:03 AM   #24
68ihscout
Oh, oh is right.
i got me in this mess , looks like ill just change the oil pan gasket and be done with it hell of a lot easier than taking timing cover off if it was the seal.
Thanks for the info and help..
