Old 08-10-2018, 09:21 AM   #1
jeffg1010
jeffg1010's Avatar
Tricks and tips on cleaning up unnecessary wires & holes in the engine compartment
I recently started on the Blazer that I’ve owned for quite a while. Yeah I know, wrong forum... but there is a lot more activity in here so since they are the same under the hood I’m posting on here.
I hate under my hood. It’s a mess. Overspray, unused holes, loose and ratty wires. It looks like crap. So I’m starting there.
Can anyone share tips or tricks on how they cleaned theirs up? There is a lot going on in the firewall area so I’m not sure what all I can get rid of. I’ve never owned a welder but I’m considering getting one just so I can get rid of all those holes. What style do I need?
And of course, if you’re gonna talk about it, we’ve gotta see some pics of yours!
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 08-10-2018, 09:26 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tricks and tips on cleaning up unnecessary wires & holes in the engine compartmen
This thread might give you some ideas...
http://67-72chevytrucks.com/vboard/s...d.php?t=659682
LockDoc
Leon
Old 08-11-2018, 10:20 AM   #3
87Skier
87Skier's Avatar
When I first got my Jimmy, I redid all the underhood wiring since I was swapping to a newer gen I small block, needed a few extra wires, and was adding relays for headlights.
I moved the windshield wash wash hose (from tank) to a hole much closer to the wiring harness, then reused this spot for the oil pressure sender hardline.
I moved the fuel gauge sender wire to the rear light harness.
The front body wiring harness was moved to run through the fender along with the windshield wash hose.
The holes were filled with a grommet assortment like this one: Amazon
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 08-11-2018, 11:49 AM   #4
jeffg1010
jeffg1010's Avatar
Love the grommet suggestion. And less that ten bucks too!
Jeff
Old 08-11-2018, 12:01 PM   #5
Jason Banks
Jason Banks's Avatar
If you have a fairly stock situation still. I would order replacement harnesses. When you disconnect the wiring from the firewall it split's into 2 harnesses. One is the forward lamp harness and the other is the engine harness.
On mine I took the engine harness and cleaned it up with lacquer thinner and re-wrapped it with the non sticky black tape. I also fixed a couple wires and changed the wire for the HEI power. I ended up getting a new forward lamp harness because I thought it was going to take too long to clean up all the old spray paint from the areas not wrapped in tape. The forward lamp harness also connectors to the alternator and voltage regulator and the whole thing was pretty stiff. I figured a NEW harness would probably give me brighter lights and better charging.
Jason Banks is offline   Reply With Quote
Old 08-14-2018, 10:55 AM   #6
jeffg1010
jeffg1010's Avatar
More good info Where are you ordering your forward lamp harness?
Jeff
Old 08-14-2018, 02:05 PM   #7
OregonNed
OregonNed's Avatar
Between replacing wiring that was cobbled together, (with the right gauge and color), and routing between the driver side inner and outer fenders, I was able to clean things up quite well. Wires were laying across everything, including the spark plug wires. The wire gutters on the firewall and at the radiator were replaced. This is as clean as I have made it so far.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-14-2018, 02:16 PM   #8
ncpetersc
ncpetersc's Avatar
That is super clean.. nice work. May my engine bay look 1/10th as nice someday!
ncpetersc is offline   Reply With Quote
Old 08-14-2018, 08:47 PM   #9
jeffg1010
jeffg1010's Avatar
Oh my ... this is why I made this thread. Motivation.
Jeff
Old 08-16-2018, 05:21 AM   #10
Rufas
Rufas's Avatar
I didn't fill any holes on the firewall. I did take body filler and filled in all small dents and dimples leaving the firewall having a 'smooth' appearance. Where possible I recalked all seams and smooth those seams before the calking dried.
Get yourself new wiring harness. Cover all wiring with Braided Wire Wraps. On the ends of the Braided Wire Wraps use heat shrink tubing. That will keep the ends from fraying and it's visually more appealing. Try to hide wiring as much as possible. My headlight wiring is behind the left fender and over the wheel well. Washer hose follows the same route. Hide the wiring for the right headlight under the top portion of the core support. The power lead from the alternator, one wire, runs over the intake manifold, behind the engine, to the positive cable on the starter. All leads for the EFI come from the back of the engine and over the intake. All wiring is covered with Braided Wire Wraps and are tied back with black plastic zip ties. Use the shortest/smallest ties possible to keep it visually appealing. Clip the zip ties as close as possible for neatness and to keep from cutting yourself on the clipped ends. Get good spark plug wires and run them from the distributor, behind the engine and preferably under the exhaust manifold/headers. You might have to get a set that you need to 'cut to fix'. If you do spend the money on a good spark plug wire crimper. There are no wires hanging off of my engine.
I'm not using the factory junction block located on the right fender that is normally connected to the battery via a fusible link. I have a six terminal buss connector mounted on the core support, under the battery tray, that connects to the positive battery post through a 40 amp fuse. That is also where relays for my electric fans are. This allows for shorter wires, the shorter the better when carrying high current to the electric fans. All my power for the truck, except starter lead, comes from the buss bar and is run behind the right fender and over the wheel well. From where the fender meets the firewall the power leads travel under the heater/AC housing and enter into the cab there.
Be consistent with all nuts and bolts. I used stainless steel almost exclusively that I hand polished. Be creative and hide as much wiring as possible. That might require modifying harness somewhat. Just use good connectors and the proper wire gauge.
Remember just to take your time and think through all options.
Taylor Diamondback Shielded Battery Cables 20238
Taylor Diamondback Shielded Battery Cables 20224
Summit Racing® Braided Wire Wraps
Here is another example of hiding wires on my 67 Cutlass with a 468 BBC.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 08-16-2018, 08:08 AM   #11
Leonard1
Leonard1's Avatar
Here's a pic of my firewall from several years ago, but I tried to label each hole for reference:
http://67-72chevytrucks.com/vboard/s...59&postcount=1
Leonard1 is offline   Reply With Quote
Old 09-08-2018, 03:34 PM   #12
jeffg1010
jeffg1010's Avatar
Where are you guys buying your wiring harnesses?
Jeff
Old 09-08-2018, 06:00 PM   #13
Jason Banks
The last ones I got I bought from some random person on ebay. Because eBay had a 15 or 20 percent off coupon going...
Old 09-08-2018, 10:16 PM   #14
darrellyates
Welded up and only added holes as necessary. Kept most things on the driver's side, changed everything on the passenger (running vintage air).
Good Luck with yours!!!
darrellyates is offline   Reply With Quote
Old 09-08-2018, 10:55 PM   #15
jeffg1010
jeffg1010's Avatar
Looks awesome!
Jeff
