Old 08-10-2018, 11:00 AM   #1
pofo
Vibration under acceleration, troubleshooting
Hi guys, pardon my english, I am from Norway.
I did a compression check today.
The engine (as far as I know):
Stock 350 with the original Rochester Quadrajet carb, no modifications.
The truck:
1976 C20 Silverado with a TH350.
It was stored outside in the norwegian winter, it was around -17C at the coldest. A buddy of mine started it up and let it idle till it got warm 3-4 times during the winter.
In springtime I drove it 260 miles without problems. After that I drove it around town for a couple of days and noticed a vibration while accelerating. It has some uneveness/shaking while in P and some throttle, maybe 1200-1600 rpm.
I got the following results:
Sylinder 1: 137psi
Sylinder 2: 150 psi
Sylinder 3: 137 psi
Sylinder 4: 150 psi
Sylinder 5: 135 psi
Sylinder 6: 140 psi
Sylinder 7: 138 psi
Sylinder 8: 150 psi
The lowest was 135 psi and the highest was 150 psi.
Are the compression OK? Whats the next thing for me to check out/do? I changed the fuel filter without effect.
Thanks for tips and answers!
pofo is offline   Reply With Quote
Old 08-10-2018, 01:05 PM   #2
geezer#99
geezer#99's Avatar
Re: Vibration under acceleration, troubleshooting
Compression’s good.
10% between the high and low reading is good.
Have you checked your spark plug wire or spark Plugs?
That will cause your problem.
Easy way to check is look at them in the dark. Hard way is to wiggle them when it’s running.
Old 08-10-2018, 01:27 PM   #3
pofo
Originally Posted by geezer#99 View Post
Compression’s good.
Wires and plugs are 2 years old. The plugs do have a lot of rust on them, and when I pulled them, some of them are a little sotty and a couple are light grey..
Should probably just change the plugs and wires, pretty easy, and doesnt cost a fortune.
Old 08-10-2018, 01:37 PM   #4
geezer#99
geezer#99's Avatar
Do the plugs first.
If you do one thing at a time you’ll find the problem easier.
And it doesn’t cost much to check your timing!
Old 08-10-2018, 04:59 PM   #5
SunSoaked
SunSoaked's Avatar
[QUOTE=Hard way is to wiggle them when it’s running.[/QUOTE]
Learned that lesson the hard way.
SunSoaked is offline   Reply With Quote
Old 08-10-2018, 08:14 PM   #6
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Does it have fresh fuel in it? Check your distributor cap inside for corrosion on the terminals.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-10-2018, 08:58 PM   #7
87Flh
87Flh's Avatar
Motor/trans mounts maybe?
87Flh is offline   Reply With Quote
Old 08-11-2018, 10:34 AM   #8
pofo
Yes, fresh fuel and I checket the distributor cap (forgot to mention that), everything looked good.
Could worn/broken motor mounts give the impression that the engine runs a little rough? I will have a look
Old 08-12-2018, 11:38 AM   #9
pofo
I am trying to figure out whats the correct plugs for the engine. Now I got ACDelco R44T with a .035" gap (according to Rockauto). Is this the correct gap for my truck?
If I look up my truck, engine and year on Rockauto I get lots of different plugs with different gaps.
Old 08-12-2018, 11:58 AM   #10
geezer#99
geezer#99's Avatar
Gap an hei at .045.
Old 08-12-2018, 12:34 PM   #11
Pontiac1976
Pontiac1976's Avatar
Does your 76 have HEI in now or points.
Maybe check the points and gap them if needed.( clean if that all they need or replace)
after doing might be good to check timing.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-12-2018, 02:02 PM   #12
pofo
Not sure actually. I think it got points. Should the gap be different than with HEI?
And whats the easiest way to tell the difference between points and HEI?
Old 08-12-2018, 02:48 PM   #13
geezer#99
geezer#99's Avatar
Yours would be hei.
Hei was put in trucks starting in 1975.
Easy to see difference.
Hei doesn’t have a coil wire in the centre of the cap, points does.
Old 08-12-2018, 02:51 PM   #14
Pontiac1976
The easy way is the cap and coil
https://www.google.ca/url?sa=t&rct=j...15GPas00x-M8Bm
Sorry 76 my mistake 75 up I must be getting old
Old 08-12-2018, 06:33 PM   #15
pofo
Yours would be hei.
Allright, thanks! So with HEI, the gap should be .045”? The plugs Ive used have .035”
Old 08-12-2018, 06:39 PM   #16
geezer#99
geezer#99's Avatar
Yes!
Most plugs are gapped at .035 new.
You need to check and gap them.
Old 09-06-2018, 05:34 PM   #17
pofo
Thought I should do a follow up.
I finally got new plugs, gapped them at .045" and it runs much better and smoother, no vibration!
Really appreciate the help, guys.
My idle is running a bit higher, but thats probably because the fresh, new plugs.
