Old 08-10-2018, 05:23 PM   #1
Cristiann8
69 shortbed emergency brake cable routing
Hello does anyone have detailed pictures of how to properly run the emergency brake cables? My 2 short cables from the drums are good but the others are ripped. I’m putting my truck together so I want to make sure how they’re ran ahead of time.
Cristiann8 is offline   Reply With Quote
Old 08-10-2018, 11:49 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 69 shortbed emergency brake cable routing
They are all pretty much the same except for in the cab and where the main cable goes through the firewall. This will give you an idea.
LockDoc
Leon
Old 08-11-2018, 12:03 AM   #3
LockDoc
LockDoc's Avatar
Here is the '67-'68 diagram.
LockDoc
Leon
Old 08-11-2018, 11:24 AM   #4
Zeroman
Zeroman's Avatar
LockDoc nailed it, again.
If you want pics, send me your email address in a PM. The pics are too large to post to the board.
Zeroman is offline   Reply With Quote
Old 03-19-2019, 11:04 PM   #5
3757chevy
3757chevy's Avatar
Rather than start a new thread , I'm adding a question . Can any one tell me what this part in the illustration is ? I have purchased every thing from the handle to the rear backing plates for my '67. Maybe I'm still missing something. Thanks.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 03-20-2019, 04:47 PM   #6
3757chevy
3757chevy's Avatar
So even after I ask for help I keep looking for the answer.... And low and behold I think the picture quality is just bad . This picture makes it clear , so it appears nothing is there.
MIKE
Old 05-19-2020, 03:06 PM   #7
Hatzman
Hatzman's Avatar
Does anyone have a photo of how the cable is routed and sits under the hood of a 1970 C10 Shortbed?
Thank you
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 05-19-2020, 04:14 PM   #8
LockDoc
LockDoc's Avatar
Thank you
The upper clamp bolts to the inner fender panel and the lower clamp bolts to the frame. Small rubber gromet where the cable goes through the firewall.
LockDoc
Leon
Old 05-19-2020, 05:25 PM   #9
Hatzman
Hatzman's Avatar
Thank you LockDoc,
You don't by chance have an actual photo of the way it rests under the hod, do you? Also, what do the clamps look like? I have a bag full of them and not sure what goes where at this point.
LockDoc
Steve
Old 05-19-2020, 08:44 PM   #10
FirstOwner69
FirstOwner69's Avatar
Here are pictures of my '69 long bed. I'd expect the cowl to frame portion would be the same as a short bed.
Jim
FirstOwner69 is offline   Reply With Quote
Old 05-19-2020, 10:49 PM   #11
Hatzman
Hatzman's Avatar
Thank you Jim!
Does the e-brake line go between the inner fender and the two brake lines going up to the master cylinder? Or around the brake lines?
Steve
Old 05-19-2020, 11:09 PM   #12
FirstOwner69
Thank you Jim!
It's rearward of the brake lines. You can also see that in the second pic of my previous post. The cable goes rearward behind the top shock mount. The brake lines run down the frame in front of the shock mount.
Jim
Old 06-07-2022, 06:40 PM   #13
LNP
Does anyone have pictures of the holes the twist hook goes in? My 69 long bed 2wd had all of its parking brake cables hooks etc removed before I bought it. My other question is which hole in the crossmember where the carrier bearing is mounted does it the cable go thru. Any help would be appreciated. Thanks
LNP is offline   Reply With Quote
Old 06-07-2022, 08:47 PM   #14
FirstOwner69
These may help. '69 C20. Longbed of course.
Jim
Old 06-08-2022, 08:33 AM   #15
LNP
That will help a lot thank you. I see a brace in photos 2 & 3 that my truck doesnt have. That must be a difference between the C-10 frame and the C-20.
