Old 11-15-2003, 06:09 PM   #1
chevychic
chevychic's Avatar
Cool Watch for falling debris....
On Halloween my truck started stalling out at stop lights. This was my first experience with a flooded carb so I had no clue what was going on at first. It didn't happen all the time, just occasionally. It wasn't until a couple of days later when I went to start it in the morning and it wouldn't start. When I opened the hood, I had gas all over the intake manifold and top of the carb.
I took off the airhorn to check the float and needle. Reset the float and inspected the needle and didn't find anything worthwhile. Put everything back together and the truck ran great for a few days. Long enough to go out of town for the weekend in my husband's car and leave my truck with him. It got him to work but barely made it back home again. So it sat through the weekend until I got home to take a look.
I learned a nifty trick to find out if the carb is flooding by looking down into the carb with a flashlight to see if gas is dripping out of the venturris. Sure enough it was.
I took the airhorn off again, inspected the needle and verified the float again, just incase....still ran bad. So this ruled out the needle and float and left the solution to be some debris in the seat. Not having been able to see any debris, I called my dad to get his opinion before going further. He told me of a trick where you plug off the fuel line, start the truck and let it run until there wasn't enough gas in the carb and it started to die, unplug the line, and the force of the gas shooting into the carb may dislodge the debris. Did this and it seemed to work. Drove it a bit and no problems so I thought I'd double check the float level one last time before calling it good since I'm not very confident in my float setting abilities. Removed the airhorn, rechecked the float level, put everything back together, started the truck and it would barely even run!! Arghhhhh!!!
Pulled the airhorn off again...I'm getting really good at this part ...checked everything, finally shined a flashlight down into the seat and there it was....
A nasty piece of rubber that had managed to get through from my new fuel line, or old one...I'm not sure which. My guess is that it would shift around in the seat and was small enough to exit the hole at the bottom of the seat and then return on occasion causing my truck to run ok sometimes and not at all other times. I was able to get it out by removing the fuel line at the carb and blowing it out with compressed air.
Even though this whole thing was a PITA, I learned a lot from this. I have 2 new tricks under my belt and I learned that the first order of business when checking a flooded carb is to get down in there with a flashlight and take a look around..that was my 'duh' moment. If you just look at it without a flashlight to shine back and forth, chances are you'll miss it like I did many times.
Anyways, here's a pic of the little devil that caused this whole mess...
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 11-15-2003, 06:23 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I used to have a q-jet that a previous had repaired with JB Weld. Every couple of months a piece would get stuck in the needle and seat. I was making minimum wage at the time, and preparing for my wedding, so I couldn't afford to do anything but take it apart on the side of the road every time it flooded over. Like you, I got very good at it after a few times...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-16-2003, 06:03 PM   #3
78SilveradoSWB
78SilveradoSWB's Avatar
Talking
At least you used a flashlight, some might have used their lighter!
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 11-16-2003, 09:02 PM   #4
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
SO how's it run now? does it still have the long drive hit & miss thing going on?
keep us informed
mike
mike reeh is offline   Reply With Quote
Old 11-17-2003, 01:52 AM   #5
Slonaker
Slonaker's Avatar
The cousin of a friend of mine once used his lighter for that. He caught my friend's all steel '32 Ford Coupe on fire briefly.
Slonaker
Stock '01 Silverado
Old 11-17-2003, 05:42 PM   #6
chevychic
chevychic's Avatar
keep us informed
mike
It runs great around town. I don't think I fixed the long drive problem, but I'll find out tomorrow.
My dad is pretty sure the carb is icing up, but I have a few things I want to try before I accept that
I'll be sure to keep y'all posted.
A lighter??? That guy definitely needs a sign
ChevyChic
86 Chevy K-10
- Christopher Robin
