Old 08-12-2018, 05:56 PM   #1
karlbenz
dual fans?
we put dual fans on my sons 63. the circuit breaker keeps kicking when it gets warmed up. can I put a bigger circuit breaker on or should I wire them separate with different relays and breakers?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 08-12-2018, 07:03 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: dual fans?
Why two fans? How big are the fans and which fans did you get?
Many electric fans pull huge amounts of amps when starting. I suggest using relays to draw your power from the battery directly as well.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-12-2018, 07:07 PM   #3
karlbenz
Re: dual fans?
2-12” fans. Came with a 30amp circuit breaker and one relay
relay is 40amp
1965 Chevy C60
Old 08-12-2018, 08:59 PM   #4
Clyde65
Clyde65's Avatar
Re: dual fans?
Got A/C?
Wire the one to come on when engine starts and then the other @160 if that’s what thermostat is.
If you have AC, then use a tri-nary switch to kick the one on with AC and at temp.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-13-2018, 06:32 PM   #5
karlbenz
Re: dual fans?
Originally Posted by Clyde65 View Post
Got A/C?
No ac
1965 Chevy C60
Old 08-13-2018, 07:41 PM   #6
Clyde65
Clyde65's Avatar
Re: dual fans?
No need for dual fans, just use a 16” spal fan, puller that pulls at least 2200 cfm
Clyde65
Rebuild of Clyde
support our troops!
Old 08-13-2018, 08:07 PM   #7
karlbenz
Re: dual fans?
No offense but I was looking to figure this here out. Not looking to buy another fan. I think I got it now though
1965 Chevy C60
Old 08-13-2018, 11:32 PM   #8
Captainfab
60-66 Nut
Re: dual fans?
I would wire them with each having it's own breaker and relay but controlled with the same sensor
Old 08-14-2018, 07:25 AM   #9
karlbenz
Re: dual fans?
That’s what I did. Thanks
1965 Chevy C60
Old 08-14-2018, 07:28 PM   #10
Clyde65
Clyde65's Avatar
Re: dual fans?
None taken, glad you got it ironed out!!
Clyde65
Rebuild of Clyde
support our troops!
