Old 08-14-2018, 11:04 PM   #1
Bird dog
Power steering lines on 67-72 swap
Ther have been a few threads on The power steering lines on a swap, but I cant find any info specific to the 67-72’s.
The “stock” gearbox has an 11/16-18 inverted flare female and the 6.2 crate pump requires that Earls extention fitting to get the lines past the pulley. I bought the Earls fittings (looks like it will work great) but because the inner fender covers the gearbox fittings, it doesnt leave room for the 11/16 to 6an adapter and a 90. I dont want to trim the fender at this point (almost done with the build). No one makes an 11/16 to an 90 degree fitting.
What has everyone done? At this point I think we’re going to resort to buying a stock 72 power steering line and using the inverterted flare fitting, building new steel lines to adapt to 6an.....
Any other suggestions?
Bird dog is offline   Reply With Quote
Old 08-14-2018, 11:13 PM   #2
Ghost's68
Ghost's68's Avatar
Re: Power steering lines on 67-72 swap
I just went down to a local hydraulic shop and had them make me lines. I’m not running any inner fenders and no pump extension. Just a adapter to go to 6an. Clears the pulley just fine.
I just used some wire and mocked up the lines with the bends and it worked out perfectly.
Ghost's68 is offline   Reply With Quote
Old 08-16-2018, 12:38 PM   #3
Steve Cole
I cannot confirm this but I heard you can just unscrew the fitting from the back of your old pump and screw it into the LS pump, allowing you to use your old line.
Can someone confirm or deny this?
Steve Cole is offline   Reply With Quote
Old 08-16-2018, 12:58 PM   #4
bs46488
I bought a new line and cut the end off to mock it in place.
Then since I don't have a TIG, i used a local mobile welder and had him weld the old line with the new style end on it. He charged me very minimal for the job.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 08-16-2018, 03:38 PM   #5
sprint_9
sprint_9's Avatar
If you have room, use the stock line and crimp a new end on it.
I've seen others use -6 line with a 90 on the pump end, but instead of running directly toward the engine they go toward the front of the truck and loop them more to get under the fender.
sprint_9 is offline   Reply With Quote
Old 08-16-2018, 07:38 PM   #6
Bird dog
Maybe the 6an 90's I had were "longer" but I couldnt get the "loop to the front" to work either......my inner fender was still too close. My backup plan was to bend the fender up to clear, but I ended up using the fitting and most of the tubing off the stock line and flaring a tubing to 6an fitting on. I used the black coated PTFE line from Russel. I had never seen that stuff before. It ended up looking like a stock line. Which I liked. I haven't taken a good pic of it yet, but you can barely see the tubing in this pic.
Old 08-16-2018, 09:50 PM   #7
flashed
Bird dog , what A/C bracket did you use ?
flashed is offline   Reply With Quote
Old 08-16-2018, 10:06 PM   #8
Bird dog
Holley high mount. I can't remember the part number though.
Old 08-17-2018, 03:03 AM   #9
ls1nova71
ls1nova71's Avatar
Yes, this will work as long as you are using a truck pump. The smaller type2 pumps found on cars it wont work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-21-2018, 06:40 AM   #10
my kids toy
what air breather system is that ?
my kids toy is offline   Reply With Quote
Old 08-29-2018, 10:44 PM   #11
Robznob11
Robznob11's Avatar
You also want to change the internals as well because the ls pump will put out more psi and make it feel real light ....mine is a truck and I just swapped and used a regular hose!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-04-2018, 12:51 PM   #12
Haggar
I don't remember the brand, but I just bought an adapter fitting for mine to go from flare to O-ring, and put a few small bends on my original 1971 line, and it fit well to my LQ4. Mine is from a Hummer H2, I think 2005. I am running a redhead steering box, no issues with any over it so far, 350 miles on the setup.
Haggar is offline   Reply With Quote
Old 11-19-2018, 05:06 PM   #13
Derek.Matirne
I just cut my line, the hard line, and used a compression fitting to join the two together, now that being said, i have not tested it yet, but the fitting should hold...
Derek.Matirne is offline   Reply With Quote
Old 11-19-2018, 06:40 PM   #14
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I went with hydroboost, so I took the stock hoses (metric and standard 71's) and had them reworked at my local machine shop with 6AN PTFE hoses. This was not a cheap way to go...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
