Upper radiator hose suggestion
I have a 1970 C20 with a 396 BB in it. I just received a Vintage Air sure-fit AC system for it. I have the alternator mounted on the passenger side and the power steering on the driver’s side. I am mounting the compressor on the driver’s side also and as per their instructions, I purchased a new radiator hose that was supposed to help clear the compressor.
The part number they suggest is GM # 3986380 ( Napa 7575 ). I installed it and even cut the radiator side a bit shorter but it still doesn’t clear the compressor. Does anyone have a suggestion on another hose I could use that might have a 90 degree bent as soon as it exits the rad? I have attached a couple of pictures showing how the hose comes out currently.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
Re: Upper radiator hose suggestion
I used one when I had a Big Block from a 1971 Chevelle. Part number from my local Autozone is E70724
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
Sometimes cross over parts aren't exact duplicates of original and other brands have to be compared. I have a 454 BBC in my '71.. Top hose is a Gates 20827.. The bend is less than 90 degrees, turns back toward the radiator somewhat.. Runs a ways then turns back toward the t-stat housing.. I don't have any pictures of the installation but the bend at the radiator neck on my Gates is much sharper and has a shorter radius than your NAPA hose..
#4 | |
#5 | |
This hose is a continental or gates. The Napa number was what was suggested by vintage air. The Napa part was 36$ this hose was 21$.
Doesn't matter who made your hose or how much it cost.. The hose in your picture looks nothing like my Gates 20827.. Mine clears the compressor -- yours doesn't..
![]() Join Date: Dec 2013
Gates 25808 1 1/2” is a flex hose with 90 at one end. I used it with Gates 26390 1 1/2” to 1 1/4” reducer for upper hose on mt LC9.
#8 | |
Now I have a few more numbers to go back to a couple of parts stores with and see what happens. I could order a hose online, but I’m trying to buy as much locally as possible.
https://www.rockauto.com/en/catalog/...pper+hose,2058
https://www.rockauto.com/en/partsearch/?partnum=20827 I can see 20607 on the hose in your pictures. Looks likes the Gates 20607. The Dayco 70724 has a nice 90. The Gates 20827 looks similar
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#10 | |
The 2 groove press fit pulley I need I was going to order from rock auto as it was the cheapest option. I called one of the local parts stores and it was the same price, after including shipping from rockauto.
![]() Join Date: Mar 2003
I'd look into swapping sides with the ac and alt
Finding a hose will be easier. I would need other brackets plus I just received the proper hose kit for the compressor.
#13 |
Have you considered stopping by your local muffler shop and having a piece of pipe bent so it fits perfectly and being so close to that A/C pulley may save you problems down the road ?
#14 |
I’m going to investigate the suggestions for part numbers first. They may just work. If not, then I’ll dig into other options.
#15 |
Post Whore
![]() Join Date: Feb 2016
I'm not sure if this will help but there are at least two styles of thermostat housings, one is straight and one that is angled to the drivers side. They have different hoses. Here is a link to my Burban's SMALL BLOCK showing the difference in the two hoses (Post 344).
http://67-72chevytrucks.com/vboard/s...698377&page=14 I can't tell which housing you have but if you can't get it to work maybe the other style would work better. I had to trim my upper hose shorter at the radiator to get it to work for me. Good luck
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#16 | |
Thanks.
#17 |
I dont know if it helps but heres a thread showing going the other way round,see if it helps? looked tight in front of pullies!
http://67-72chevytrucks.com/vboard/s...d.php?t=723941 |
#18 |
With the rad that I have and the big block arrangement I’m using, if you look at one of the last pictures, you will see the rad exits almost straight into the compressor. Once I adjust it to tighten the belts it will be directly in front of it.
#19 |
I have a bbc in my 68 GMC and the rad hose came with the motor whitch was out of a 1975 chevy 1 tone. It has a tight turn at the inlet hose to the rad and runs parrallel to the rad it might be what you need.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
#20 |
Could try this upper hose for a 87 Chevy V10 pick-up, it had A/C on driver side and alternator on passenger side. CONTINENTAL 61564
https://www.rockauto.com/en/moreinfo...300868&jsn=457 |
#21 |
I stopped in at one of the parts stores and ordered another hose. 70724.
I checked his screen and it looked correct. Went back this morning to pick it up along with some belts. A little trimming and now there’s lots of room.
