Old 08-15-2018, 06:10 PM   #1
rmawyer
1970 C10 Speedo Cable Replacement
Speedometer needle skipping. Truck has a 68 inch cable that goes from speedometer to a coupler (maybe for cruise control?) in engine bay. There is a second lower cable from same coupler to transmission that is about 55 inches long. Home mechanic friend used drill to show upper cable working; subsequently determined lower cable is broken, needs replacement. Not having any luck on tracking down a replacement cable. I may not be using the correct cable name in my online searches. Any ideas on where to look? Also, is the cable unique because of the cruise control? As always, thanks for any insight shared.
rmawyer is offline   Reply With Quote
Old 08-16-2018, 07:12 AM   #2
ncpetersc
ncpetersc's Avatar
Re: 1970 C10 Speedo Cable Replacement
https://www.summitracing.com/parts/o...del/c10-pickup
Maybe?
Don't know what engine/tranny you have, but the length of this matches what you are looking for.
ncpetersc is offline   Reply With Quote
Old 08-16-2018, 08:48 AM   #3
rmawyer
Thanks for the information and confirmation, since it matches one I was finally able to locate on the JEGS site. I still don't know if the cruise control matters, but I took a chance and ordered the part anyway.
Old 08-16-2018, 09:12 AM   #4
ncpetersc
ncpetersc's Avatar
I think cruise/no cruise may just change the length.
Old 08-18-2018, 09:41 AM   #5
rmawyer
Thanks for responding!
Old 08-28-2018, 11:05 AM   #6
rmawyer
Re: 1970 C10 Speedo Cable Replacement - Still not working
I replaced the lower speedometer cable and still have same symptoms: needle skipping, sometimes stays at 0 MPH, never goes higher than 20 or 30 MPH. I've been told there are 4 major parts involved - the speedometer, the upper cable from the speedometer cable to an engine bay coupler, the lower cable from the engine bay coupler to the transmission, and a plastic (?)gear in the transmission. Since I replaced the lower cable with no improvement, and I have a replacement upper cable, should I try that next? Again, thanks for any advice.
Old 08-28-2018, 01:43 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
If you don't have cruise I would have replaced the two with a one piece cable. Did you lube the upper cable? You might try that, just pull the upper cable out, wash it down with solvent and lube it with a little light oil.....
LockDoc
Leon
Old 08-28-2018, 04:32 PM   #8
rmawyer
Thanks. The truck does have cruise control. Is that the purpose of the upper and lower cable coupler in the engine bay? I was told I don't have to lube the cable but I can try that and see if it makes a difference.
Old 08-28-2018, 04:36 PM   #9
LockDoc
LockDoc's Avatar
I don't know a lot about the cruise but if it has it I would leave the two piece cable....
LockDoc
Leon
Old 10-09-2018, 05:29 PM   #10
rmawyer
Re: 1970 C10 Speedo Cable Replacement - double speed
I removed the cruise control transducer since it was disconnected electronically. I was then able to run only one speedometer cable directly from the speedometer to the transmission. The good news is the speedometer is now working. The bad news is it is now registering about twice the MPH (60 for 30, 100 for 50). Since the speedometer seems to be working, do I now need to focus on the gear inside the transmission? Thanks for any assistance.
Old 10-09-2018, 06:59 PM   #11
LockDoc
LockDoc's Avatar
You may be correct on the transmission gear. That is a lot of difference. I wonder if one of these would help you....
http://67-72chevytrucks.com/vboard/s...d.php?t=758806
I don't really know for sure, but just throwing out suggestions.
LockDoc
Leon
Old 11-20-2018, 12:24 PM   #12
rmawyer
Here's the latest. Took truck to a mechanic. He said the coupler / transducer needed to be repaired or replaced, since one of the receptors for a cable had become rounded. Even though I'm not hooking up the cruise control for now, I found a transducer replacement. Now I'm going to connect the two cables to the transducer. Here's my challenge - trying to find a GM cable roughly 36 inches long for the speedometer to transducer without having to make a custom cable. Anyone know where I can get one? No problem getting the lower cable. If this does not fix the speedometer issue I'll next replace the transmission drive, driven, and speedo gears. Thanks.
Old 11-20-2018, 02:39 PM   #13
demian5
demian5's Avatar
Why not put a small amount of some tin foil on the end of the cable and shove it in and see if it works?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-20-2018, 05:58 PM   #14
rmawyer
Thanks for the suggestion.
