Old 08-16-2018, 03:03 AM   #1
Funstuie
76 C10 bushing kit recommendations (and suspension upgrades)?
Hey all
I’m looking to buy a bushing kit as all the rubber is either decayed of cracked and weathered on my truck. It all needs replacing. Is there a good option for a kit?
Also I would like to replace the shocks and I’m looking for comfortable ride over style. Any recommendations?
It looks like nothing has been replaced since the 90’s (if at all) on this truck, so I would like to give a little perk me up.
76 c10 stepside.
Funstuie is offline   Reply With Quote
Old 08-16-2018, 12:21 PM   #2
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Re: 76 C10 bushing kit recommendations (and suspension upgrades)?
Stay away from polyurethane. Rubber is just fine and gives a better ride for a daily driver. I got a cab bushing kit from LMC Truck and the suspension bushings are all from Moog.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-16-2018, 02:14 PM   #3
billlopez
I rode in my friends with Bilstein shocks. Really firm ride if thats what you like.
billlopez is offline   Reply With Quote
Old 08-16-2018, 05:37 PM   #4
LT7A
Well, they say everybody has their own opinion. I have replaced rubber bushings with polyurethane on a handful of cars and noticed a subtle improvement in handling if I was looking for it but never thought of it as an increase in harshness. More durable as well.
Bilstein usually has comfort and heavy duty shocks available for each application. The comfort configuration has been the single biggest improvement I've noticed in suspension rebuilds.
Old 08-16-2018, 08:16 PM   #5
Ziegelsteinfaust
Personally I am a big fan of PST poly graphite pieces. Personally I have never had one of the several sets I used squeek.
If your looking for better handling out of your truck. Move the lower A arm forward 1 inch, and I believe lower the upper 1/2 inch. Then toss on the usual suspects, and it really wakes up the truck in that department.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-16-2018, 08:29 PM   #6
69heavychevy
69heavychevy's Avatar
I used PST polygraphite bushings because I kept hearing how good and squeek free they were. Well after a few thousand miles they are squeeking. It's not terrible but it's noticeable. Yes I did use plenty of grease when I installed them, and yes I torqued them down with the suspension loaded. Funny thing is on my leaf springs I used the regular red energy suspenion polys and those are squeek free.
If I had to do it again I'd just use moog rubber bushings and call it a day. I didn't really notice any difference in handling characteristics from rubber vs polyurethane on my truck.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 08-19-2018, 11:49 PM   #7
MikeB
MikeB's Avatar
I installed Energy Suspension poly control arm bushings on my 82 C10 last year and love them. In fact, whenever I replace any kind of suspension bushing on an old car or truck I use Energy Suspension. They are easier to install, don't deflect as much as rubber (which means better handling), and will probably never crack. And I've never had them "creak" in past installations. Of course I always follow their instructions and use their silicon grease.
If the ride is more harsh, I haven't noticed it. And it's a pickup for cryin' out loud, not a Cadillac!
BTW, I used Moog ball joints, tie rod ends, Pitman arm, and idler arm. It's the only way to go, IMO, and not too expensive at RockAuto.com. Most of the "kits" use crappy parts.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-20-2018, 07:34 AM   #8
Pontiac1976
Pontiac1976's Avatar
For me rubber or Energy Suspension. The new one now have changed for the better over the 20 years.
But if you are lazy do not do yearly maintenance of cleaning/lubing or if you do lot driving or the roads push the body lot and your in a hot area you may have to lube every 6 months or more if they are working. the less they work the longer they lube last.
I like the feel in my Pontiac that I did late 80's I had to replace a few As in the early years I did not clean lube enough because I worked them a lot in a 4200LB car it can harsh. Oh rust will eat at them they do some movement bare metal start rust like sand paper. Did my truck with Energy Suspension. My truck is harsh with 9Leafs spring so it Truck like stand in a bus and ridding in it hold on and love it. lol
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-21-2018, 08:48 AM   #9
jkk
jkk's Avatar
Go MOOG and be done
jkk is offline   Reply With Quote
Old 08-21-2018, 02:23 PM   #10
RedBed
RedBed's Avatar
I just bought all the parts you are talking about, including KYB shocks and coil springs. Priced it all at RockAuto and the prices were good, but shipping was high. I ended up getting everything (all MOOG) on Amazon (Prime).
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
