1969 C10 Winshield Washer Nozzles
My current C10 had washers nozzles at one time and are no longer on the truck. I am trying to find out how these nozzles are mounted and run all new hosing, Reservoir, and Pump to the truck. I think the only part I cannot figure out is how to mount the nozzles.
Any Help here would be appreciated. I think I have to take the cowl off but not sure?? |
Re: 1969 C10 Winshield Washer Nozzles
Yes crowl has to come off.
Holes under crowl for the hoses. I simply added a newer 12v pump and wired it to the switch. Works awesome
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Here is a picture of my 68 without the cowl cover on, so you can see the nozzles. Sorry its not a better picture but its all I have. If you can save it and zoom in, you can see the nozzles. The hose goes through the hole in the front face of the top of the fire wall just to the left of each nozzle. Each nozzle only has one sheet metal screw holding it in place.
1968 SWB Step Side, Big Block, 4L80E , Running! |
The brackets that mount the nozzles are made onto the nozzles. 15 a pair @ lmc.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
Thanks everyone that responded, got the washer nozzles installed for the most part. Great Forum!!
Also....Welcome aboard!... I may go with later model resivoir and pump, with plastic nozzles... or the nozzles on the wiper.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
| Bookmarks |
