08-17-2018, 06:31 AM | #1 |
62 Clutch hose????
I have a 62 c10 that needs the small hose between the stock master cylinder to the hard line leading to the clutch slave cylinder.
If part number unavailable then specs would be great. |
08-17-2018, 11:55 AM | #2 |
Re: 62 Clutch hose????
I had Nevada House of Hose redo my line. Because "Happiness is a good hose job!" As their bumper stickers state.
https://nevadahouseofhose.com Find local shop, I got mine if your in for Vegas trip.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-17-2018, 12:42 PM | #3 |
Inline Tube also has them.
08-18-2018, 12:41 AM | #4 |
Bring your old one down to Royal Brass on tenth st in San Jose they will make one for you.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-20-2018, 02:03 PM | #5 |
1960 GMC Burb
Same here. I took the old hose down and had a local company make the section between the two tubes. Cost me about $45.00
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
08-23-2018, 09:22 PM | #6 |
Thank You all for the help.....I'll be searching my home area for a reputable spot.
08-24-2018, 02:54 PM | #7 |
I guess you are talking about the rubber line? Stock is rubber to a hard line.I bought a re-po line and it was just one piece of tubing, so no flex when installed. I used two an adapters and a braided #4 stainless line.
1961 chevy K10 my build is------------61K10 build |
08-24-2018, 10:59 PM | #8 |
@61K10.... would appreciate a pic if possible.
thanks. |
08-25-2018, 02:44 PM | #9 |
I have sense changed from stock setup. don't remember how long the hose was. here a pic and pics from summit racing
08-26-2018, 12:45 PM | #10 |
61K10 F'n awesome thanx...
