Gen I 350 & 4l80e
I have a gen I 350, non-vortec in my truck. I want to bolt up my 4l80e to it while I build my 6.0l.
Can I reprogram the PCM that came with my 6.0l swap to control just the 4l80e and disable all the engine controls? If I cannot, should I buy a 0411 PCM from a 2001-2002 van and have that reprogrammed to disable all engine functions, but still functional to control the transmission.
Customization is what you want it to look like -- not what other people think it should look like |
Moderator
![]() Join Date: Jun 2017
Re: Gen I 350 & 4l80e
There are standalone trans controllers available but seriously...
why not grab a 4.8 or a 5.3 wrecking yard engine and throw it in.... Will need a simple reprogram of the ECM...but when the 6.0 is ready, it will be an easy swap... ![]() ![]() ![]() |
![]() Join Date: Oct 2009
Yes, LS era are great engines. To me, and maybe just me, they don't exactly look right in the bay. I think the Gen I with a 4L80E is a GREAT combo. Is an LS a better engine? Yes, but perhaps that's not the only question to be answered when considering a swap. Don't get me wrong, I've sure thought about doing one too - but I always come back to a 350 being good enough - and looking a lot better. In actuality, I prefer an HT383 with valve cover adapters, and a 4L80E (or NV4500, or some sort of O/D for drivability). Again, that's just me
#4 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
In order to run the 4L80E you would need a controller for the trans. The factory TCM will not work. In addition, you would need some adapters to make the trans work with a 350. Both things you need to make it work would not be used when you put the 6.0 in. My opinion would be to just wait. It’s not worth the extra money to put the trans in first.
#6 | |
I THINK the GM parts are discontinued (part # 24502540), but they pop up for sale from time to time. I found two at a tiny Chevy dealer in Kentucky - the same one I knew growing up when I spent summers there - and they just decided to clean out the warehouse. Think I found them on ebay. Saving them for the eventual HT383 install, and since they were much less expensive than the engine, well, I got them first! Ha. Last edited by jocko; 08-18-2018 at 12:51 PM. |
#7 | |
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
