11-16-2003, 01:42 AM | #1 |
Auto Column Shift Levers?
Is there a difference between the tilt and non tilt shifter lever in an auto column? If so, can a non tilt shifter be used or modified to work in a tilt column? I've located aftermarket non tilt shifter levers, are the tilt shifter levers available aftermarket?
LJ
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
11-16-2003, 02:02 AM | #2 |
its all about the +6 inches
They are not the same.
Do you need a replacement...or are you looking for a custom touch? |
11-16-2003, 02:11 AM | #3 |
Thanks Longhorn. I'd prefer a replacement, but I'd be open to a custom part, depends on the appearance.
LJ
11-16-2003, 02:22 AM | #4 |
I'd post a WTB thread on the parts board.
I may be able to get my handson a tilt gear selector lever...but not untill (next) friday ant the soonest. |
11-16-2003, 02:50 AM | #5 |
11-16-2003, 03:09 AM | #6 |
Thanks Paul. Can you or anyone describe the difference between the two? Better yet a picture of the two?
11-16-2003, 03:28 AM | #7 |
I don't have one of the tilt shift levers here at home but heres a scan of the non-tilt shift lever end that inserts into the steering column,
the tilt one I will get a pic of Monday at latest if I don't grab one later today from the office. On the tilt ones where the hole is on the non-tilt it has material removed about 1/3 of its thickness on either side and forms a curved dish. " Hope you understand that explanation its a little hard to explain as they say a pics worth a thousands words. " The tilt column lever end that inserts into the column is about 1/2 as long as a non-tilt is also. Big differences you could never confuse the 2 by looking at the end that goes into the column. GMCPaul |
11-16-2003, 03:33 AM | #8 | |
LJ
11-16-2003, 02:14 PM | #9 |
No pic of a tilt one here either. but that ball is missing and it looks more like a machined edge that slides into a notch.
For lack of better words. |
11-16-2003, 09:07 PM | #10 |
This is what the end of a tilt lever looks like and you can see the difference as compared to GMC Paul's pic.
Jim |
11-17-2003, 02:30 PM | #11 |
Tilt Shift Lever
GMCPaul |
11-17-2003, 02:38 PM | #12 |
LOL hurried home at lunch to scan, upload to web site, and post this pic and did so without waiting to see that JimKshortstep4x4
already posted a pic. LOL GMCPaul |
11-18-2003, 03:52 PM | #13 |
Thanks Guys, pretty significant difference in the two.
LJ
11-18-2003, 04:08 PM | #14 |
Thats also the same one used in the 70's van tilts. So thats another option if you want to check the boneyard.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
