Old 08-20-2018, 06:41 AM   #1
Andyking1203
Talking Brake pedal bracket question.
Is there a differance between a auto brake pedal bracket, and a manual bracket, other then 1 has a clutch pedal on it? Thanks
Andyking1203 is offline   Reply With Quote
Old 08-20-2018, 09:21 AM   #2
Smitty
Smitty's Avatar
Re: Brake pedal bracket question.
No! The brake pedal can be removed.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 08-20-2018, 09:29 AM   #3
Andyking1203
So I can use the manual brake pedal bracket, and just remove the clutch pedal and move the brake pedal over?
Old 08-20-2018, 09:37 AM   #4
71cadc10
71cadc10's Avatar
I think you remove the clutch pedal, once you remove the end with the linkage rod on it, you can knock the clutch assembly out thru the bracket.
and then you have an auto setup. No moving of the brake pedal that I'm aware of.
I have an auto setup, and a 3 on the tree setup and the brackets/brake pedal portion are identical.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 08-20-2018, 10:30 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
'71cadc10 is correct, you just remove the clutch pedal and shaft, the brake pedal stays where it's at. It can be hard to get to with the assembly in the truck though.
LockDoc
Leon
Old 08-20-2018, 03:25 PM   #6
Andyking1203
Ok guys awesome thanks... didn't want to have to hunt down a unnecessary parts..
Old 08-20-2018, 03:26 PM   #7
Andyking1203
LockDoc
O it isnt in the truck!!! Truck is in 4k pieces atm..
Old 08-20-2018, 06:23 PM   #8
LockDoc
LockDoc's Avatar
Good deal. That will make it easy.,
LockDoc
Leon
Old 08-20-2018, 09:49 PM   #9
saon
are the brake pedals between auto and manual different? is the auto 1 wider than the manal?
saon is offline   Reply With Quote
Old 08-20-2018, 10:15 PM   #10
Andyking1203
I think it's just the size of the pad
Old 08-21-2018, 07:17 AM   #11
Andyking1203
So to keep the theme.. I have read that you can convert a 4 wheel equipped drum brake truck to disc useing stock parts, (in front). Is this true? Also is it possible to do the same in the rear? And is this suggested, or is it worth just putting after market brakes? And if the aftermarket is the way to go, what size rotors? Plan to run a 17" wheel.I plan to use 2.5" lowering spindles, and 4" lowering rear springs. Thanks for the opinions.
Old 08-21-2018, 10:32 AM   #12
Jens Jimmy
If you are staying 6 lug, you can use 71-2 front rotors from a 4wd. They will work on the rear. I have two of them set up like that. i just made a mount for my caliper and a spacer. Both of mine are 4x4 trucks, that are 72's, so they were front disc already, I have not converted a front 6 hole with the rotor, but I cant see why it wouldnt work. I dont have an e brake set up on my caliper, love to figure that out reasonably. I have pics if it would help you picture it.
Jens Jimmy is offline   Reply With Quote
Old 08-21-2018, 03:27 PM   #13
Andyking1203
Mines a 2wd, the 71/72 setup i figured would work, and yes I'm staying 6 lug.
