Old 08-21-2018, 04:52 PM   #1
Drew3
69/70 hood emblem
Does anyone have measurements for drilling for a 69/70 hood emblem? I have a 71/72 hood and want to add the emblem.
Drew3 is offline   Reply With Quote
Old 08-22-2018, 11:27 AM   #2
Drew3
Re: 69/70 hood emblem
Bump
Old 08-22-2018, 12:09 PM   #3
tdangle
tdangle's Avatar
Ill measure for you when I get home tonight.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-22-2018, 02:24 PM   #4
bill3rail
bill3rail's Avatar
After some exhaustive site searching, I found absolutely nothing for templates!
Did you call all the body suppliers? Someone must have it.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-22-2018, 04:17 PM   #5
Shinysideup
Shinysideup's Avatar
Check this out, tape on verticals is hooked on lip.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 08-22-2018, 05:45 PM   #6
Drew3
Thank you. I have looked and looked and came up with nada.
Old 08-22-2018, 11:55 PM   #7
tdangle
tdangle's Avatar
I also measured, but from the top edge of the hood. the higher driver side hole is 2.55 inches down, the passenger side is 3.95" down. The driver side hole from the closest edge of the center body line is 1.10" to the right same measurement for the other side. All measurements are to the center of the hole. Hopefully this matches up with the other measurements posted above. I would make a paper template and double check all with the actual hood emblem prior to drilling holes. Always better to measure twice, three times before cutting or in this case drilling
Terry
