![]() Join Date: Oct 2012
wtb shifting rods from a 67-72 3 speed
I am needing a set of shifting rods from a 67-72 c10 with the 3 speed on the column price shipped to 72560 Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: wtb shifting rods from a 67-72 3 speed
i will ship you a set for $50 total. They are from a 6 cyl truck saginaw transmission.
![]() Join Date: Apr 2003
6 cyl. or V8 ?
The rods that shoveldug has should work for you.
Do you have paypal
Posted via Mobile Device |
If nothing works out I have a bunch of the rods. But they are all mixed up and I'd need help sorting out what is what
Yes I do. It is dwl65101@yahoo.com I also sent you a PM
Ok money sent Thanks
Just a heads up the shifting rods from a 67-69 chevy truck will not fit a 65 with a 68 3 speed transmission
Those were 67-72 6cyl rods for 3spd, correct? And you are saying those will not work on a '65 with V8 and 3spd. So have you tried 60-66 V8 rods for 3spd? Is the engine mounted in the 6cyl position (dist. back into the firewall) or the V8 position?
They will not work on my truck. I have a 350 with a 68 3 speed. The truck is a 65. The rods are too short and will not clear the firewall and the clutch z bar. I was under the truck a while trying everything to make them work. I have not tried the 60-66 v8 rods. I think the engine is in the 6 position but not sure. The original bell housing was in the truck when I got it bolted to the factory cross member right behind the engine.
#13 |
Are the engine frame stands in the front or rear holes? How much room between the distributor and firewall?
#14 |
The back holes but like I said the bell housing is bolted to the front cross member. It cannot move forward to my knowledge Any way I went today to buy a tranmission and driveshaft from a guy and ended up buying the whole truck so I will have everything I need to put the right 3 speed in it
