Power brake petal drop question
I have installed a stock power brake setup on my 68, and I don't have the engine running yet. I have bleed the brakes but the pedal will still go down slowly if I keep pressure on it. Is this normal with power brakes and no vacuum?
1968 SWB Step Side, Big Block, 4L80E , Running! |
Who Changed This?
![]() Join Date: Jan 2013
Re: Power brake petal drop question
What all changed? Did you just add a booster and master? Do you have the shoes all adjusted to the drums?
Petal is very firm and doesn't go far down on the initial push, but with continued pressure it moves slowly down to the floor.
Who Changed This?
Is it the old master cylinder? That's a symptom of a bypassing piston, which indicates that it should be replaced or rebuilt.
Brand new. Its a 1 1/8" bore for power brakes. Took off my 1" bore manual brake master to install it.
laying low
![]() Join Date: Mar 2001
The fluid is going somewhere. It's either bypassing inside the master or there is a leak somewhere.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
![]() Join Date: Mar 2005
I agree not right. Should hold up longer than your leg will. Either a leak in the system or a bad master cylinder
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
