Voltage Regulator?
My buddy recently go a 69 C/10 and we noticed that he does not have a voltage regulator, would there be a reason why the PO would have removed it?
![]() Join Date: Dec 2012
Re: Voltage Regulator?
He probably put in an alternator with an internal regulator...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Is there a more of a benefit to one or the other?
I'm guessing the internal type is solid state, and external is not - one less failure point?
Internal does a much better job of voltage control, and is friendlier to electronics.
1968 SWB Step Side, Big Block, 4L80E , Running! |
Well, there ARE solid state external regulators readily available from any reasonably stocked parts store. BUT, the conversion to an internally regulated alternator is a very common upgrade for many reasons including the solid state nature of the regulator in internally regulated alternators.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
This thread pretty well covers it.
http://67-72chevytrucks.com/vboard/s...d.php?t=763180
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Very simple to convert to an internally regulated alternator.
Mine is externally regulated, however I do carry an internally regulated spare in the back because it was free. That and the crossover connector so I do not need to splice wires on the side of the road when she craps out. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#9 | |
#10 | |
Msgt USAF Ret
Have you noticed the lights dimming at idle or the wipers moving slower or the heater fan not running at full speed on high? It's possible you may have one of the 60 amp alternators which will probably serve you well. If you plan to add cooling fan(s) you might consider the upgrade. If you have no issues then by all means run the EVR. You can get a digital regulator for about 30 bucks. I think someone mentioned that above.
I have not noticed the lights dimming and the wipers work just fine. I guess I should be ok since I am not having any issues at the moment. Thanks for all the good info guys!
