11-16-2003, 04:02 AM | #1 |
Need advice... sorry a long post!
This is my 1972 Cheyenne Super, Shortbox with factory 402BB, Air, Tilt, Tach, Cruise and bucket seats. I have had this just sitting for about five years now... collecting the parts for the resto.
I have collected new original Gm inner and outer fenders,Rad Support, and Gm tailgate. The bedsides, front bed panel and inner box wells are Goodmark. The hood cab and doors are mint so I am going to keep them. I have all the new chrome and interior as well as all of the steering and brake parts to make her new again. I have assembled the truck with the new body panels now to ensure they all fit well together. It seems to be ok the doors have a nice alignment as well as the front clip. It was fairly painless getting the gaps and body lines to come together. My plan is to blow the chassis apart and have it all powdercoated. My question is to those of you that have been down that road before... I want to take all of the panels to bare metal and start fresh with a good epoxy primer to start the body work off right. I was hoping to paint everything off the chassis individually in stages. Such as the cab and doors first, put them on the refinished chassis and then the front clip and at last the box. I will be painting her black so it shouldnt be hard to match the paint. I was hoping to get some feedback on this procedure maybe some pros and cons of doing it this way. Maybe you might suggest a better way. Sorry such a long post thanks for the time.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 |
11-16-2003, 04:10 AM | #2 |
Tried to send this with the original message but here it goes again.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK. My build thread: http://67-72chevytrucks.com/vboard/s...=1#post7120181 Last edited by super72bb; 11-16-2003 at 04:20 AM. |
11-16-2003, 04:21 AM | #3 |
huh ???
It's best to paint all of your body panels at the same time. The reasoning for this is unless you have a climate controled paint booth you can never get the same temp of humidity. The color will be close but will never be 100% the same. Just smething I picked up from working in and around body shops for 3 years...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-16-2003, 04:30 AM | #4 |
mmm thats gonna be nice if you bag it, put it on some 20s, put tribal flames all over it and shave everything
70 longbed 496/th400/Ford 9" |
11-16-2003, 04:56 AM | #5 |
Merciless Butcher
I paint all of my trucks in pieces. But my garage is heated with a forced air heater with a sealed combustion chamber. I prefer doing it that way because Everything gets painted. There's no manuvering the gun around tight spaces. BTW, I live in the desert so humidity isn't much of a problem. Chuck is right though, temp and humidity play a big factor in color match. Good Luck..Greg
Your Bought And Sold....I Got Your Soul! |
11-16-2003, 05:27 AM | #6 |
Mine was done in peices, but we used the same booth for everything, took us all day, I liked the fact that you don't get any masking lines when you do it in peices
11-16-2003, 05:55 AM | #7 |
I think the biggest concern would be the type of black being sprayed. Buy enough to finish the job and if it's a metallic mix it all at once because it will likely not match otherwise.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
11-16-2003, 08:22 AM | #8 |
i love summertime
dont do what dinnut said! heavens no..ha no offense dinnut but a truck that rare, if original shouldnt be touched, id go full out C.P.N.E on its ass
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
11-16-2003, 11:40 AM | #9 |
Resident Curmudgeon
I agree with the paint advice here. Nice truck there by the way.
DINNUT, I like your club name but did you know the acronym for it is SOBS (or SOB's) Full out CPNE! Good one
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-16-2003, 11:41 AM | #10 |
Watch out for your cornhole !
I've painted several of mine apart. I color sand and buff all areas, including inside bed and back sides of fenders. As long as you color sand every piece, any difference in texture will be negated.
I painted my orange truck in pieces over the course of 3 months, with no problem with color difference over the whole truck. Believe me, I'm a picky M.F. and I won't tolerate mis matched panels. Since you're painting it black, you should be good to go concerning color continuity over the whole truck.
11-16-2003, 11:54 AM | #11 |
You have to be carful painting metalics when the truck is in pieces. If the direction of paint application isn't the same as the ajoining parts then the flip of the metalic can be different and even though all other factors are the same the paint may not match panel to panel. It's kind of like the nap of a fabric or a piece of carpet. If the grain isn't the same way it reflects light different and it doesn't look right.
Saskatoon, Saskatchewan Canada |
11-16-2003, 04:44 PM | #12 |
CPNE??? What that mean??
Brandon |
11-16-2003, 04:56 PM | #13 |
lol. i see ur back on the board brandon. if that was my truck i wouldnt touch it. i was just sick of seeing stock trucks last night so i said that same thing in about 30 different threads.
11-16-2003, 05:57 PM | #14 |
i love summertime
lol dinnut, i noticed that, i was like holy sh it he loves dubs and tribal flames..lol i also do but not a on bb cheyenne shortbox thats loaded...
11-16-2003, 08:02 PM | #15 |
Life, Be In It.....
Thanks for the question. I had the same concerns and now I know. I need to assemble my truck and have the body work done then take it apart for paint.
11-16-2003, 08:02 PM | #16 |
Life, Be In It.....
Do you have any pics of the progress up to now. We would all enjoy them. Please post some pics.
