Old 08-23-2018, 10:50 AM   #1
Caleb1534
12 Volt Outlet doesn't work...
Our 1994 Chevrolet K1500 Silverado Z71's 12-volt outlet doesn't work.
Any ideas on how to fix it?
Does the 12-volt outlet have an associated fuse in the fusebox?
I really want to get it fixed because it's pretty annoying to need to use another vehicle to plug my portable air compressor into to air up our truck's tires.
Any thoughts or ideas y'all share will be greatly appreciated!
Caleb1534 is offline   Reply With Quote
Old 08-24-2018, 07:39 AM   #2
Re: 12 Volt Outlet doesn't work...
I believe the outlet/cigarette light fuse is #13 of the inside fuse box near driver's side kick panel.
Palf70Step is online now   Reply With Quote
Old 08-24-2018, 04:44 PM   #3
diveplane
yea check fuse first.
diveplane is offline   Reply With Quote
Old 08-26-2018, 10:33 AM   #4
Kudzupatch
Kudzupatch's Avatar
My 93 suburban's failed and I have read that it is common issue with the wire breaking. I was just going to pull a new wire to it but changed my mind. I installed two plugs in the console. I use them for USB power and they are out of sight.
Kudzupatch is offline   Reply With Quote
