![]() Join Date: Jun 2005
Brake banjo bolt question
Is the banjo bolt the same between drum brakes and disc brakes? I am converting to front discs Johnny Cash style and am collecting all the parts first before I begin the project. If they are the same, I will just reuse the ones from the drum brake wheel cylinders. Thanks in advance for any replies.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: Brake banjo bolt question
drum brakes don't use a banjo bolt, the hose will thread directly onto the wheel cylinder, maybe your asking about if it will connect to the hard /soft line junction? in that case you'd have to make sure you get the correct sized fittings for the new disc hose to match up. most after market hoses for disc use the common 3/8x24 but you can find them in the 7/16 size.
Thank you for the reply rynobuilt. I feel like an idiot now. It's been a few years since I replaced the hoses, and I didn't remember they thread in directly. I have new hoses for the conversion, and I have calipers on order, but I don't think the calipers come with the bolts. I searched the site and cannot find a definitive answer on what length the banjo bolts need to be. I also searched the web and none of the big box auto parts stores have a listing for banjo bolts for a 1972 C/10, which is the application I am using to buy all the parts to make the disc conversion.
laying low
![]() Join Date: Mar 2001
Maybe check a Wagner or Raybestos or Rockauto site.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
No dice
you'll probably use the 7/16" ones.
https://www.speedwaymotors.com/Searc...njo%20Fittings |
![]() Join Date: Dec 1999
I used Dorman 484200
I have an extra hose kit with the banjo bolts , compression washers that came with my conversion kit fit gm calipers from 71 -87 I went with stainless steel ones you can have for the price of the ride
How long are the hoses? I bought short ones from Autozone
I will have to check later today dont have them here at home now
sorry took so long the package says 16 inch
My hoses need to be much shorter than that. I will pass, but I appreciate the offer.
#13 |
Thanks for all the replies, I found that Dorman p/n 484-203.1 (7/16-20 x 1 1/16) worked for me with Autozone p/n 88466 hoses.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 09-10-2018 at 05:01 PM. |
