Clutch rod too short
I have a 1968 k20 pickup that I recently dropped a 350 in the aft frame mount locations. Behind it is a sm465 4speed. I have everything put together and was missing the clutch rod that went from the bell crank to the clutch fork so I bought one from lmc and it is significantly too short. 4-6 inches too short. Thought about just making my own but curious if anyone else has had this problem and if so what was your fix?
Thanks ! |
![]() Join Date: Mar 2003
Re: Clutch rod too short
Can you post up pictures of the area and mounts, bell crank etc
![]() Join Date: Feb 2002
I probably have the longest clutch pushrod in the County. When the OEM one wouldn't throw the clutch back enough, we were too lazy to pull the SM465/NP205 thingie and change out the throwout bearing for a shorter one.
So we went all out. I bought a '73/'87 Squarebody lower clutch pushrod and spliced them together, with a 3'' section of sawed-off 9mm submachinegun barrel over the weld-joint. Works. Long clutch throw. [3 Finger Borg and Beck pressure plate] Rig is '71 GMC Jimmy: 350 V8, SM465/NP201, 3.73:1 12 Bolt Corp w/Auburn posi, on 33x12.50x15LTs. Only drawback is that you need a 2'' ratchet strap to pull back the clutch fork for maintenance on the upper clutch rod at the Z-Bar junction. A related gripe is the Z-Bar pivot wore a hole in the driverside header collector. AWM, as work intervenes.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-24-2018 at 01:59 AM. |
![]() Join Date: Dec 2013
I dug into my parts bins and here are a couple pics of the different size rods the short one is 9 1/2" and the long one is 13 1/4"
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
bell cranks/mounts
#6 | |
I got pulled into working night shift for the next few days I’ll try to get out there and see what I’m working with as far as length and get some pictures of what I have. thanks |
![]() Join Date: Oct 2015
If you got yours from LMC it will be about 9 1/2". I needed one for a 4x4 as well and could not find one. Ended up taking two to make one. They do come up on the parts board from time to time.
