Lessons learned
My son has been driving the C10 around a week or so because his truck needs a few items addressed.
He says the starter is hanging up after starting for just a second, and when you rev the motor is grinds too. He pulled the starter, looks fine, puts it back in and says now it hangs up, makes a whine when starting and grind when revving. We get another starter and before installing, take a look at the truck. I pulled the plastic TC cover off a while ago because it was shot, ring gear looks great. Sure enough when he and his friend pulled the starter off, since there was no nut on the starter bracket at the front (yes it still has it), the starter was put on straight up (did it at night - didn't see bracket). So it was tweaked towards the ring gear. Loosened the starter and bracket and put through the bracket hole, voila! No more whine, but still sounds like its hanging up and when revving. Popped the hood, listen to the noises, sounds like the motor... the damn upper alternator bolt threads let go and the alternator was up against the valve cover. Luckily the belt was still fairly tight! So lesson learned for the kid about diagnosis. No more grind and all is well with the world. Now to fix his truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Lessons learned
Glad you found it and it was an easy fix.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Moderator
![]() Join Date: Jun 2017
Re: Lessons learned
Be ever so thankful he said something...and was interested enough in assisting with the fix...
So many young people, both genders, are not interested in our art...sad to live in a disposable world... ![]() ![]() ![]() |
#4 | |
![]() Join Date: Jul 2015
Re: Lessons learned
I always drill out that silly threaded aluminum thingy and put a nut and bolt through there with a couple of thick washers. |
Re: Lessons learned
It's when there are two unrelated things making what appears to be one problem that we have the hardest time diagnosing. When I had a alternator bracket bolt let go in the head it was real obvious. Gauge went to hot, so I drifted into a parking lot. One bolt had sheared, the other pulled the threads out, alternator/bracket was laying there. No brainer
#6 | |
Posted via Mobile Device |
