Old 08-25-2018, 01:11 PM   #1
1BAD65
65 C10 FUEL SENDER RATING 30 or 90 OHMS ??
Need a little help here guys.
1965 C10 LWB converted to SWB
Original gauge cluster with original fuel gauge.
I removed the tank behind the seat and scrapped it years ago, so I no longer have the original fuel sender
Just ordered a new under bed tank from Tanks Inc. and now need to order the correct fuel sender for the stock fuel gauge.
I need to know if the 65 C10 trucks came with a 0-30 or 0-90 ohm fuel sender.
Originally the truck came with an inline 6 cyl engine, not sure if you need that info but just in case.
I have searched here and get conflicting information. Some threads say all GM vehicles are 0-90 some threads say 0-30 for certain years.
Is there a way to pull the gauge cluster and test the fuel gauge without power?
The truck is in pieces since this is a frame off restoration
I do have a Snap On battery charger if I need power or I can use a standard car battery from my daily driver.
Any help or links is GREATLY APPRECIATED
1BAD65 is offline   Reply With Quote
Old 08-25-2018, 03:30 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 65 C10 FUEL SENDER RATING 30 or 90 OHMS ??
Sending units are 30 ohm.
Old 08-25-2018, 06:15 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Yep, the fuel level gauge in the instrument cluster reads a 0 ohm empty to 30 ohm full signal.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-25-2018, 07:25 PM   #4
1BAD65
@TheRocknRod and @ Vin63
THANK YOU !!
YOU GUYS ARE AWESOME!!
